06 trailblazer 4.2 4/4 LT 58000 miles Electronic heater controls
Replaced battery with a deka 800 cca. The old battery was ac delco 600 cca. Replaced battery because of weak starts when cold and it showed 12.1 volts engine off. Took for a ride and heater blower stoped then started back up 2 times as i hit the brake. Then i stoped went into store and came out and started it up and lights dimmed real bad for 5 to 6 seconds then ran fine. Checked battery it is at 12.5 volts engine off and 14.4 volts engine running. Checked ground and power to see if they were lose and they are tight. Trying to pin point what the problem is any help would be great.
Thank you
Thank you
