Been about 2 years since I had to do anything on my 2002 TB. It has a new "feature". With everything turned off, it is draining the battery. When I disconnect the negative lead to the battery, there is quite a bit of sparking. The charging system seems to be working, the battery tested at 13 volts, disconnected from the system, when I got home tonight.
Any thoughts on how to measure the draw when the key of off? Any ideas how to trouble shoot this issue?
I was thinking, if I could measure the draw, I could pull fuses, one at a time and see if this changed the draw. That should isolate which circuit the draw was coming from. Of course that assumes that the draw is coming from a fusable link I can pull the fuse on.
Thanks,
-Dave
Thanks,
-Dave
