Are both U-Joints on the rear driveshaft the same?
03envoy
537
After replacing the further most U joint Im getting another noise that is almost Exact to the one I was hearing when I replaced the U joint that connects the driveshaft to the rear axle, but now it seems to be further up and points to the other U joint at the transmission. Are they the same size? Going to go under there soon and see if that's what it is. Thanks,
Trent
Did you reassemble the driveshaft in phase? Meaning the U-joints lined up, oriented the same front and rear? Did you get all the C-clips installed?
Nevermind, scratch that. They will only go in one way. Which joint did you get? I have had bad luck with the Prescision joints and should have gone with Spicer originally, would have saved me a couple bucks.
03envoy
537
I replaced the first one with Moog. The Non-Greaseable one. I'm going to order the same one off rockauto.
rmsg0040 said:
I believe the rear driveshaft only has 1 u-joint
front one has 2
this is for 4x4
The rear has two but are a pain since they are epoxied in place....new ones take C-clips for retention.
You just need a propane torch or better yet MAPP gas and heat the yoke until the epoxy melts. That's the small white pimple-looking bump on the yoke.
It's possible to overstress the yoke when removing the u-joint if you don't heat it...not common but possible.
rmsg0040
285
Yes you are correct,
Front has 1, rear has 2
Did mine earlier this year, as said use a torch
Fishermandude
