Hi all
Now i really need some help.
I have a problem to pass inspection due to my airbag warning light is on now and then.
I have some time ago removed the passenger airbag and replaced it with a airbag simulator, basically a resistor to fool the computer.
That has worked well for over a year, but i have had some issues with flaky connection at the simulator due to the thin wires to the airbag.
When the connection is lost at the airbag sim i always got the message "service airbag system".
Now i have fixed that flaky connection some time ago and it has worked well.
Before and after i fixed it i experienced some strange flashing from the warning lights, both airbag and seatbelt lights.
First both lights will come on, after a while the seatbelt light is starting to flash for a quite long time and then go out. But the airbag lamp stays lit.
There is NO info on the DIC about "service airbag system"
This happens on every startup or ign on. There is quite a difference in how long time that will pass before this happens tough.
Sometimes right away, and sometimes it will be ok for 10 or 15 minutes before it comes on.
I went to a shop today to get it scanned for codes and we found two.
With ign on we found U1088 "lost SIR/SDM communication". With the engine running a second code appears together with the first and it is U1000 "class2 data link malfunction"
Whats going on, where should i start looking.
