Hello one again working on my moms rainier.
The rear air bags were completely deflated I've seen it like this before but once its started it pumps back up, but for the past two days it hasn't pumped up I drove it Saturday and it was fine so sometime Monday this happened .
when car is started the compressor runs for maybe 15-20 seconds rear bags don't inflate , if you turn the pump on via the switch it runs till it times out putting out 45-50 psi so its pumping fine.
while moving it in and out of the garage trying to get it positioned just right the pump turned on and the bags started to inflate like normal ( maybe a little slower ) turned the car off shut the door and listened for a leak but couldn't hear one.
I know the switching valve in the pump is a known problem should I look at this or is it more of a sensor issue?
