When checking my air filter, I had trouble replacing the cover. The small separate plastic piece at the radiator sits in a groove and in addition to the main opening that blows into the box near the filter, there is a hole on top that appears would fit into a hole in the cover. Just past the filter, in the cover, there is another hole that another opening on the main duct would fit into, just beyond where it connects to the filter. Neither fits tightly. Wouldn't this would cause air to come into the filter housing, some going through the filter and being filtered, and some being blown around and going through the opening past the filter into the main duct and continuing on unfiltered? If the rubber on the hole in the duct isn't fitting tightly into the hole of the cover, it seems like unfiltered air could go right into that duct opening and continue on.
If this is correct, it may explain why I seem to have a lot of sand and grit when I removed the duct from the resonator after undoing the clamp. The clamp wasn't as tight as it should be, so I'm sure that's why some of the sand and grit could get out at the resonator for me to see it all around the edge of the duct where it connects. Seeing all of that dirt is what had me checking out the clamp and then the air filter housing etc.
While trying to piece this together, I noticed there is a notched area in the edge of the cover that would fit onto a raised notch on the top of the washer fluid reservoir. No matter how I try to screw it down with the raised notch of the reservoir fitting into the notched out area of the air filter housing cover, it doesn't come together. They simply meet up to each other and they fit as far as size but the lid doesn't seem to go down far enough to actually fit it together, or the reservoir doesn't seem to be up high enough. If it is supposed to fit in each other but doesn't, wouldn't that be sending more air into the air filter area since it's technically sitting higher and may have gaps?
1: will the rubber fitted openings on the two pieces of the ductwork in and out of the air filter cover not being attached to the lid firmly cause dirt to continue on in my system?
2: is there a tip to fitting them together when screwing the lid down? or do I likely have something warped and where would be a good starting point based on the notch issue from the washer fluid reservoir to the air intake cover notch? If I take everything off, I can fit the rubber into the opening of the lid. It's when I try to lay them in the top of the reservoir first and then meet the lid up to it that I can't connect them. Putting all three pieces back in at once without them coming loose is not an option.
3: perhaps the holes with rubber on the ductwork pieces are a shallow fit so the notch issue is actually what's causing the whole lid to be up too high and those openings to not snug tight into the cover?
I am supplying pictures I found online.
