Aftermarket Exhaust Option
Zaab
122
Ohio
Does anyone have aftermarket exhaust recommendation? Mine has a minor exhaust leak around the manifold and I was thinking, if I'm going to work on it, why not install a better one? Mainly looking for reduced back pressure while maintain the same level of volume.
Since you have the 5.3, systems for the TBSS with the 6.0 will work except for those that specify that only work with 2WD (mostly headers).
If looking for an aftermarket replacement for the stock system (i.e. quiet), check the mufflers as some are necked down inside. Not sure for the 5.3 but the 4.2 uses an oddball 2.75" pipe and the aftermarket mufflers (Walker for sure) are necked down from 2.75" to 2.5".
We do have this thread:
If you want to read more:
  • Love
Reactions: Zaab
tracy.reich
