Adjustable 5100 series Bilsteins or In Strut Lift Spacer.
c good
690
Now that I'm keeping the Envoy after the Fuse 28/PCM fiasco has been solved, I want to go back to my original intention. I wanted to just lift the front end a little to level it out. At the time...in 2008 I bought a set of 1.75 inch, in-strut spacer from MarkMC on Trailvoy. I never installed them as I was waiting to replace the struts at the same time as installing the spacers.
I need to replace the rear shocks soon also. If I go with the 5100's up front should I go with the same in the back? I will be pulling a small 2500 LB travel trailer.
Now, I've noticed Bilstein makes a height adjustable strut in their 5100 series.
What is the better way to go? Thx for any input.
Reactions: 2advanced
10,818
Yeah those came out right after I bought the same kit from Mark to lift my front end. Getting the adjustable struts is the route I would have gone, if I knew about that option at the time.
I have the 5100 in the back and they're good shocks, fairly stiff but not overly. If and when I do the fronts, I'll go with the 5100 adjustables to level it out.
jagman
