- Dec 4, 2011
- 276
My AC failed a couple of days ago (just in the middle of hot and humid weather of course). Checked all obvious things, fuses, low pressure side, jumped low pressure switch (compressor did engage). Thought maybe the lines to the rear HVAC unit had leaked, so I decided to bring it to a local shop. They found the condenser was leaking, rear unit lines were good. Replaced condenser and did a full service on system. Have Coolness again!
I had just last week replaced the Power Steering oil cooler because of leakage. Northeast winter corrosion does a wonderful job on our vehicle!
Also had them replace all four sway bar end links (sourced from Detroit Axle), they had become loose again. They also found passenger side upper ball joint bad, replaced both sides. Performed an alignment. Total bill was pretty large, but work was done well and in a timely fashion.
