jsheahawk
Any PAG oil considerations? 150, correct? Just 2 oz. to re-lube the condenser, but none in the accumulator. Correct?
Yep. Just take off the grill, the head lights, and the black plastic cover behind the grill. Make sure you take the top two plastic mounts off of the condenser so you can wiggle it out between the two vertical rails. That took me about thirty minutes to figure out. The condenser is attached to the radiator with a couple bolts. Then there is the inlet and outlet on the left and right sides of the condenser. There are no bolts on the bottom. It just sits in the mounts at the bottom.Had my A/C checked today, hole in the condenser somewhere
Is there anything specific I need to know when replacing it on a 06 9-7X? Do we have some steps (& pics?) writeup somewhere? Haven't found it.
I hope the cooling system doesn't have to be touched and that I only need to take off the lights and the front bumper & grill...
Yep. That's it. Make sure the picture matches the one in your truck.Thanks for the info!
By accumulator you mean the thing that sits in the upper left corner of the engine bay that Rockauto calls "A/C Receiver Drier / Accumulator"?
Any seals or gaskets or rings I need to buy separately?
I don't know about the Saab, but my TB has red/blue sliders, and the OEM one worked. There was some talk of non-OEM units having fewer coils and being less efficient.Will the DENSO 4770858 condenser work properly on a 9-7X (RockAuto sells it for it)? RockAuto has a ACDelco one but it says it's for "Dual Zone Climate Control with Manual Controls (blue/red dials only)" ...which the 9-7X never had AFAIK. What kind of BS is that?
As for the accumulator and the orifice tube I'm planning to go with Four Seasons (parts 83222 & 38887). I'm limited to what I can find on eBay because going through RockAuto means even higher shipping costs plus the necessity to handle import taxes on my own... no thanks.
Do I need any special tools for undoing/re-assebmbling any of the join points I'm going to touch to make sure the system is sealed properly?
So, got the Haynes manual today (2002 - 2009 TB, Envoy, Rainier, Bravada).
- it says I need to remove the radiator???
- Haynes says one ounce of PAG oil in the new condenser, @jsheahawk you put in two, right?
Nope. Take start by removing the grill, and work your way toward the condenser from there.So, got the Haynes manual today (2002 - 2009 TB, Envoy, Rainier, Bravada).
Daniel...
This link is a tiny sidebar HJ ...not related to the post ...but I thought you would want to have it for other lubrication maintenance issues later:
http://www.amsoil.com/MyGarage/VehicleLookupPrint.aspx?url2=2005+SAAB+9-7X+S
Yeah, unless it's been evacuated and plugged, I'd pass on it.If it's for the same engine, it should fit. But, being used, you don't know what in there as far as contamination is concerned and these types can't be flushed. Unless they can guarantee it was removed from a sealed working unit, I would be careful or pass on it.
Things won't get any worse if you leave it how it is.So I finally got all necessary parts together but now I'm thinking I might postpone the whole job to the next spring... We won't get that many A/C-requiring days here during September.
The question now is whether leaving the circuit as it is (with the hole in the condenser) during the whole winter can irreparably damage and/or pollute it. Can the whole system get so dirty that it won't be enough to just change the orifice tube, condenser and accumulator and vacuum and refill it? Can I prevent it somehow, e.g. by plastidipping the damaged condenser?
Maybe it's an irrelevant question because I've already been driving with the damaged condenser for 3 months anyway...
Did you try taking the plastic tabs off the top of the old condenser? I was able to get mine out by taking them off and rotating it and holding my tongue right.I desperately wanted to be able to take out the condenser without touching the coolant circuit and taking out the shroud & fan but it just doesn't work. Not even just unbolting the fan and tilting the radiator a bit helped...
Nope, because I don't think it would have made any difference. The piping on the sides of the condenser was what I think caused it to be such a PITA. Note that the condensers differ across GMT360 models and MYs. Maybe you have a less space-intensive type in yours...?Did you try taking the plastic tabs off the top of the old condenser? I was able too get mine out by taking them off and rotating it and holding my tongue right.
Out of curiosity why were you so squeamish about the radiator coming out? 2 hoses 2 lines and presto out it comes lol... after the fan and shroud obviously...shit the fan is the PITA part
I didn't want to loose too much coolant (didn't have enough at home to fill up) and also didn't want to damage the radiator. I'm in Central Europe and getting most parts for a GMT360 here is a question of several weeks, if not more (or astronomical money... or both). Damaging a radiator = undrivable vehicle and that would be a death sentence for me, especially before a family road trip.
