My AC Clutch decided to give up the ghost on a trip back from NH... burned out the bearings in it.. lovely times, any recommendations on a cheap replacement compressor? I put on a shorter belt for the time being...
Mine went out the same way I installed a new bearing but pressing the wheel back on all the way was hard and my belt slipped off I ended up putting in an AutoZone compressor I bought one off of eBay but ended up getting the wrong part so while the car was apart I just went to AutoZone and grab one eBay cheapo’s aren’t worth itMy AC Clutch decided to give up the ghost on a trip back from NH... burned out the bearings in it.. lovely times, any recommendations on a cheap replacement compressor? I put on a shorter belt for the time being...
I just ordered a GPD from rockauto... good times ahead...I've had good luck with GPD, which are new made in China. Never heard anything good about Four Seizin, new or rebuilt. Actually never had good luck with any rebuilt.
I ordered a compressor kit, has compressor (prefilled with oil), orifice tube, dryer, and some o-rings... My compressor is fine, didn't detonate itself, just the clutch failed... I was going to try to find a used clutch to put on it, but when I pulled the old clutch off, the inner race stayed on the compressor. It's more of a pain to try to remove that then to change the whole thing. I have some refrigerant left attached to my gauges, but I need to purchase some extra.I've replaced both the Sierra's and Accord's A/C compressors within the last couple of years. Both were Denso (and that was OEM for both, too).
Just pay attention to whether the new one ships with compressor oil inside, or not.
Also, since the system will be evac'd when you pull the compressor, it's a good time to replace all the o-rings that join the piping together (you can get kits that have all the sizes in one bag). Lube the seals with a wee bit of compressor oil when you replace them.
Finally, a lot of companies will insist on you also replacing the receiver / drier (and even the condenser!) in order to fully warranty the part. Unless the internals blew up, I'd leave the condenser as-is. The receiver/drier is fairly cheap (that's the big silver cylinder that attaches to the firewall). If you replace that, it's supposed to have about 1-2 oz of compressor oil (or pour any existing out of the old one, and subtract that amount from one ounce -- the Sierra's was dry when I took out the old one.)
The last part in this path is (on GM) the 'orifice tube' (it's located between the receiver outlet and the hose it connects to.) Either the outlet or inlet side (I forget which), but you'd see it when you disco the hoses from the receiver. Those are also fairly cheap, and if you're going to replace the receiver, I'd spring for the extra few bucks for the orifice tube, too. They break easily, so take care when inserting it. It can also be a bit of a pain to dig the old one out of the hose (pick tools help).
I have frosty A/C in both vehicles now, fwiw.
PS: If you're recharging the A/C yourself, I'd get a couple of extra cans of R134a, as it won't be long before the same thing happens with R134a as it did with R12 -- manufacturing ceased, and the existing supply just kept going up in price, for the few years you could still find it, afterward.
I got mine from WalMart a couple of years ago; bought about a dozen cans, since all three of my vehicles use R134a.
I've used Four Seasons and they do suck, will never buy again. They like to whine around 2000 rpms and fail early. Maybe that's why they call it four seasons, that's how long they hope it lasts !I've had good luck with GPD, which are new made in China. Never heard anything good about Four Seizin, new or rebuilt. Actually never had good luck with any rebuilt.
