- Mar 30, 2012
- 252
Ok, this is a strange one. Today it was about 80F outside and I tried using the ac for the first time in the city. After a couple minutes stopped at a red light the ac would blow warm and you could feel the pump turn on off every 5 seconds or so. Then I noticed the temp gauge was going up. It went almost to the second line after 210. I would say a about 230. When the light turned green and I would travel a couple minutes it would go back down and the AC would be cold again also. I traveled about 10 minutes and pulled over and checked the fan and the coolant level. The temp went back up as I sat there with the ac on and the ac pump turning on and off. I was able to stop the fan with my leather wallet pretty easily, no resistance. After shutting the ac off, after a couple minutes the temp went back to normal. I drove across town to eat and after leaving the restaurant the ac worked fine, stayed cold at every stoplight and the pump stayed on as far as I could tell. went to a friends house and let it run for almost 10 minutes with the ac on and the temp didn't move above normal and it stayed cold the entire time.
The coolant level is good, had the water pump replaced last week, t-stat replaced in February. The ac and recirculation were both on. Have only had the T-blazer since end of January. I tried researching but found nothing with both scenarios combined. Hopefully I was detailed enough for someone to help, or has had this happen to them. Thanks for any input I'm stumped!
![Confused :confused: :confused:](/forums/smilies/confused.gif)
