NEED HELP ABS, Seatbelt lights on
nozzleman
23
Started off intermittently that the ABS and Seatbelt lights would come on in damp weather. Now they are on permanently. It flashes no codes. I even reset the codes and it's still there. Has anyone experienced this? I tried a search to no avail.
8,084
Cant help you any on the seatbelt one..
However, the ABS one could be a wheel speed sensor. They get gummed up, or a rust build up on them from the ABS Tone Ring. On the front, its really as easy as replacing the hub (comes with new sensor and wire). The rear I have yet to do, so I dont know.
nozzleman
23
They come on as a pair. Not sure if it's related but the map sensor DTC came on (P0107 low voltage). That one did throw a code.
What are you using to read codes? For ABS codes, you need more than just a basic reader to get those.
Check all your grounds
Electrical Ground locations
Another possible shotgun you could try is the ignition switch which can cause some electrical gremlins.
nozzleman
23
Found a bad wheel sensor. Being winter, I had the shop that does my Corvette work replace it. Functionally, the brakes and abs work like it’s supposed to. He says that the body computer gets all of the signals it needs but the abs and belt lights are on, due to a short or open somewhere in the wiring, making the lamps stay lit. I’m at a loss as to where to start. Any ideas?
For the belt light, yeah, it's likely a wiring issue or a bad switch in the buckle. For the ABS, you'd need to read the codes to know what's going on.
cornchip
637
This past Wednesday, my wifes 2006 Equinox was disabled in the driveway with 'low power' and about a half dozen ACC pedal related codes stored. I did some checking online and found a possible cause. Our Equinox has a leaky sunroof and last summer filled up the front drivers floor pan with water and has likely leaked since. GM bulletin # 07-06-04-019E describes how water flows down the front windshield pillar and into a major harness called 'IP connector' or more correctly C203. This connector is behind the drivers left side kick panel and is common across multiple other different GM models. After finding the connector (it's a 1"x3" harness to harness connector with a cam lock).....I disconnected and reconnected a good dozen times and filled one half of the connector pins with dielectric grease before final reassembly. This instantly fixed the low power,ABS and one other light. The check engine codes I cleared separately with a scanner. It now is flawless.
While it's 99% unlikely to be your issue, renewing all accessible connectors is worth the effort as the number of vehicles this affects is staggering. I copy and pasted the list. FYI.....different symptoms occur like low power,buzzing speakers or inoperative power windows ,ABS light etc for different models while they all share this exact same plug.
PDF LINK
cornchip
637
  • 2005 Astro
  • 2007-2013 Avalanche
  • 2005-2006 Avalanche 1500
  • 2005-2006 Avalanche 2500
  • 2005-2008 Aveo
  • 2005-2011 Aveo LS
  • 2005-2011 Aveo LT
  • 2005 Blazer
  • 2017-2018 Bolt EV LT
  • 2017-2018 Bolt EV Premier
  • 2005-2007 Cab & Chassis Silverado 3500
  • 2007-2012 Cab & Chassis Silverado 3500 HD
  • 2010-2015 Camaro LS
  • 2017-2018 Camaro LS
  • 2010-2018 Camaro LT
  • 2010-2018 Camaro SS
  • 2014-2015 Camaro Z/28
  • 2012-2015 Camaro ZL1
  • 2017-2018 Camaro ZL1
  • 2011-2017 Caprice PPV
  • 2012-2015 Captiva Sport LS
  • 2012-2015 Captiva Sport LT
  • 2012-2015 Captiva Sport LTZ
  • 2005 Cavalier
  • 2005 Cavalier LS
  • 2005 Cavalier LS Sport
  • 2005-2012 Chevy Express G1500
  • 2005-2012 Chevy Express G2500
  • 2005-2012 Chevy Express G3500
  • 2005-2012 Chevy Express H1500
  • 2015-2018 City Express LS
  • 2015-2018 City Express LT
  • 2005 Classic
  • 2005 Cobalt
  • 2010 Cobalt
  • 2005-2010 Cobalt LS
  • 2005-2010 Cobalt LT
  • 2006-2007 Cobalt LTZ
  • 2008 Cobalt Sport
  • 2005-2010 Cobalt SS
  • 2005-2012 Colorado
  • 2015-2018 Colorado
  • 2015-2018 Colorado LT
  • 2015-2018 Colorado WT
  • 2015-2018 Colorado Z71
  • 2017-2018 Colorado ZR2
  • 2005-2013 Corvette
  • 2013 Corvette 427
  • 2010-2013 Corvette Grand Sport
  • 2017-2018 Corvette Grand Sport
  • 2014-2018 Corvette Stingray
  • 2006-2013 Corvette Z06
  • 2015-2018 Corvette Z06
  • 2015-2018 Corvette Z51
  • 2009-2013 Corvette ZR-1
  • 2014-2015 Cruze Diesel
  • 2011-2015 Cruze Eco
  • 2015-2018 Cruze L
  • 2016 Cruze Limited Eco
  • 2016 Cruze Limited L
  • 2016 Cruze Limited LS
  • 2016 Cruze Limited LT
  • 2016 Cruze Limited LTZ
  • 2011-2018 Cruze LS
  • 2011-2018 Cruze LT
  • 2011-2015 Cruze LTZ
  • 2016-2018 Cruze Premier
  • 2005-2013 Cutaway G3500
  • 2015-2018 Equinox L
  • 2005-2018 Equinox LS
  • 2005-2018 Equinox LT
  • 2008-2016 Equinox LTZ
  • 2017-2018 Equinox Premier
  • 2008-2009 Equinox Sport
  • 2014 Express 1500
  • 2014 Express 1500 LS
  • 2014 Express 1500 LT
  • 2014-2018 Express 2500
  • 2014-2018 Express 2500 LS
  • 2014-2018 Express 2500 LT
  • 2014-2018 Express 3500
  • 2014-2018 Express 3500 LS
  • 2014-2018 Express 3500 LT
  • 2013 Express G1500
  • 2013 Express G2500
  • 2013 Express G3500
  • 2013 Express H1500
  • 2006-2011 HHR LS
  • 2006-2011 HHR LT
  • 2008-2010 HHR SS
  • 2005 Impala
  • 2008 Impala 50th Anniversary Edition
  • 2014 Impala Eco
  • 2014-2016 Impala Limited LS
  • 2014-2016 Impala Limited LT
  • 2014-2016 Impala Limited LTZ
  • 2014-2016 Impala Limited Police
  • 2005-2018 Impala LS
  • 2006-2018 Impala LT
  • 2006-2016 Impala LTZ
  • 2005-2013 Impala Police
  • 2017-2018 Impala Premier
  • 2005-2009 Impala SS
  • 2005 Malibu
  • 2008 Malibu Classic LS
  • 2008 Malibu Classic LT
  • 2013-2014 Malibu Eco
  • 2008-2010 Malibu Hybrid
  • 2016-2018 Malibu Hybrid
  • 2016-2018 Malibu L
  • 2016 Malibu Limited LS
  • 2016 Malibu Limited LT
  • 2016 Malibu Limited LTZ
  • 2005-2018 Malibu LS
  • 2005-2018 Malibu LT
  • 2006-2015 Malibu LTZ
  • 2005 Malibu Maxx
  • 2005-2007 Malibu Maxx LS
  • 2005-2007 Malibu Maxx LT
  • 2006-2007 Malibu Maxx LTZ
  • 2006-2007 Malibu Maxx SS
  • 2016-2018 Malibu Premier
  • 2006-2007 Malibu SS
  • 2005-2007 Monte Carlo LS
  • 2005-2007 Monte Carlo LT
  • 2006 Monte Carlo LTZ
  • 2005-2007 Monte Carlo SS
  • 2005-2013 RV Cutaway G3500
cornchip
637
And a few more...
  • 2005-2012 Silverado 1500
  • 2016-2018 Silverado 1500 Custom
  • 2005-2006 Silverado 1500 HD
  • 2014-2018 Silverado 1500 High Country
  • 2013 Silverado 1500 Hybrid
  • 2013 Silverado 1500 LS
  • 2015-2018 Silverado 1500 LS
  • 2013-2018 Silverado 1500 LT
  • 2013-2018 Silverado 1500 LTZ
  • 2015-2018 Silverado 1500 SSV
  • 2013-2018 Silverado 1500 WT
  • 2013 Silverado 1500 XFE
  • 2005-2012 Silverado 2500 HD
  • 2015-2018 Silverado 2500 HD High Country
  • 2013-2018 Silverado 2500 HD LT
  • 2013-2018 Silverado 2500 HD LTZ
  • 2013-2018 Silverado 2500 HD WT
  • 2005-2006 Silverado 3500
  • 2007-2012 Silverado 3500 HD
  • 2015-2018 Silverado 3500 HD High Country
  • 2013-2018 Silverado 3500 HD LT
  • 2013-2018 Silverado 3500 HD LTZ
  • 2013-2018 Silverado 3500 HD WT
  • 2007 Silverado Classic 1500
  • 2007 Silverado Classic 1500 HD
  • 2007 Silverado Classic 2500 HD
  • 2007 Silverado Classic 3500
  • 2012-2018 Sonic LS
  • 2012-2018 Sonic LT
  • 2012-2016 Sonic LTZ
  • 2017-2018 Sonic Premier
  • 2013-2016 Sonic RS
  • 2017-2018 Spark ACTIV
  • 2014-2016 Spark EV LT
  • 2013-2018 Spark LS
  • 2013-2018 Spark LT
  • 2014-2017 SS
  • 2005-2006 SSR
  • 2014 Suburban 1500 LS
  • 2014 Suburban 1500 LT
  • 2014 Suburban 1500 LTZ
  • 2016-2018 Suburban 3500 HD LS
  • 2016-2018 Suburban 3500 HD LT
  • 2005-2013 Suburban C1500
  • 2005-2013 Suburban C2500
  • 2018 Suburban FL
  • 2005-2013 Suburban K1500
  • 2005-2013 Suburban K2500
  • 2015-2018 Suburban LS
  • 2015-2018 Suburban LT
  • 2015-2016 Suburban LTZ
  • 2017-2018 Suburban Premier
  • 2005-2012 Tahoe
  • 2018 Tahoe FL
  • 2008-2013 Tahoe Hybrid
  • 2013-2018 Tahoe LS
  • 2013-2018 Tahoe LT
  • 2013-2016 Tahoe LTZ
  • 2012-2018 Tahoe PPV
  • 2017-2018 Tahoe Premier
  • 2012-2018 Tahoe SSV
  • 2005-2009 TrailBlazer
  • 2018 Traverse High Country
  • 2018 Traverse L
  • 2009-2018 Traverse LS
  • 2017 Traverse LS Base
  • 2009-2018 Traverse LT
  • 2009-2016 Traverse LTZ
  • 2017-2018 Traverse Premier
  • 2018 Traverse RS
  • 2015-2018 Trax LS
  • 2015-2018 Trax LT
  • 2015-2016 Trax LTZ
  • 2017-2018 Trax Premier
  • 2005-2008 Uplander
  • 2005-2008 Uplander LS
  • 2005-2008 Uplander LT
  • 2005 Venture
  • 2005 Venture LS
  • 2005 Venture LT
  • 2011-2015 Volt
  • 2016-2018 Volt LT
  • 2016-2018 Volt Premier
nozzleman
23
nozzleman
23
04 Envoy BTW.
no codes are showing and brakes and belts work normally.
I have to believe that there is something in the dash lamp circuit , in between the bcm and lamp that may be pinched or oxidized. Just don’t know what connectors or grounds are involved Or where they are.
TJBaker57
2,907
Colorado
04 Envoy BTW.
This was previously asked but I don't see it answered.... Do you know for a fact that the scanner used actually communicates with the EBCM, BCM, SIRS, etc. modules? Many, if not most scanners only request emissions related codes and never even attempt to connect to anything but those modules that deal with emissions.
This statement seems a little off to me. The indicator light for the ABS is not controlled by the BCM. It is controlled by the ABS system (EBCM module). Unless he means that the EBCM is getting a signal from a wire like a wheel speed sensor that is shorted or open?? Similarly, the seat belt switch isn't wired to the BCM at all. That switch is wired to the SIRS module.
For clarification/confirmation,,, we are talking about the actual seat belt reminder indicator and not the similar looking airbag warning light located just to the right of the seat belt reminder? And if it is in fact the seat belt reminder that is on do the chimes also sound??
And there are no wires between the BCM or EBCM or SIRS modules and the indicator lights, they are turned on or off by data messages, not direct wiring. One could think of it like the various modules sending a text message to the cluster telling it to turn on or off lights x, y, or z. You cannot short circuit that. So if it is indeed a short or open they would need to be in more than one system and be located in that system and not between the cluster and the system.
Now if there is a communications loss between the module that is controlling an indicator light and the cluster then the light for that system will turn on.
Here is an example where I turn off the airbag light on my benchtop setup. The first time it is seen to go off for several seconds then turn back on. It comes back on because the cluster does not see a "node awake" message from the system that turned the light off.
But the second time when I keep sending a state of health (node awake) message (seen on the phone screen) the light stays off until I stop sending that "node awake" message.
Fishermandude
