DgTerrell
- Joined
- May 22, 2012
- Posts
- 25
As of late my AC has been giving off a moldy aroma. At times it gets so bad that I have to turn it off because it's given me a headache. (I'm sensitive, I know). I've done my research and seen that other people have had this problem as well. Most solved their problem with cleaning out a clogged AC drain. I've checked and my tube was clear. The other reason I've found people have a stench is from mold on the evaporator. I've read that this can be fixed by spraying a cleaner that treats this problem into the center vents and goes onto the evap to cure the problem. I've found that the best product for this is 1Z Einszett Kilma Cleaner.
On the product website,( Klima-Cleaner Air Conditioner Odor Eliminator | einszett Car Care Products ) it says for recommended professional application only. I'm not really sure why it says that when the directions look so simple. It also says for certain vehicle makes, but doesn't have a list of which ones. Does anybody know if I'm safe to apply this stuff to my Trailblazer?
There's two different ways you can apply. The first is to spray it through the center vents How to apply einszett Klima-Cleaner and the 2nd is for a more direct application How to apply einszett Klima-Cleaner - Professional Application. I would like to do the professional apply. How hard is it to get to the blower motor fins to spray? Or am I just as well off to do the easier application?
Any help is greatly appreciated!
