Dad-O-Matic
- Joined
- Dec 5, 2011
- Posts
- 228
Lately the temps here in Dallas have been over 100[SUP]o[/SUP], and of course the A/C can't keep up. It takes 10-15 minutes for it to start cooling on the front A/C, but the rear A/C cools almost immediately. I had a coupon for cheap A/C inspection at Firestone, and they told me that I had a pinhole leak in the condenser.
Here's my questions:
I know that the front and rear have separate condensers, but they're both feed by the same compressor, so wouldn't a leak in front also depressurize the back and it wouldn't cool either?
Or are they somehow isolated idk, via a one-way valve?
Okay here's the rant:
I know Firestone is only good for tires and alignments (barely), and they want to screw you on everything else, but there's not enough lube in the world that I would let them screw me this bad and allow them to replace the condenser. Here's a partial breakdown of what they wanted to charge me, partial only because I stopped them after the first few quotes.
Condenser $450 (because it comes straight from AC/Delco?)
Accumulator ???
2.6 lbs of R134 ???
Labor $387
Total $1256 !!!!!
Went on Rockauto and here's the approximate prices they had:
Condenser $100 (Genuine A/C delco)
Accumalator $80
R134 $14.99 lb x 2.6 = 38.97 (from O'Reilly's)
Total $218.97
Plus Firestone Labor $605 total out the door
I calculate that as about a 400% markup on the parts, that's worse than a stealership I think. Also when I got it back there was no freon in it. When I brought it in it at least worked partially.
Screw Firestone, I don't think I'll use them again no matter how much their tires are on sale
Accumulator ???
2.6 lbs of R134 ???
Labor $387
Total $1256 !!!!!
Accumalator $80
Total $218.97
