New to the site. Looking to get an idea of where my time is best spent diagnosing the problem with the 5.3L LH6 engine on my 9-7x. Back around the holidays, it started with a DTC code for Catalyst Efficiency below Threshold Bank 2. I had seen this months before, so I did a reset to see if it showed up again. It did and stays on. But my emissions test isn’t for another year so I figured I’d wait for warmer weather before looking at addressing that.
Around that time I started experiencing what sounded like lifter noise about 10 seconds after startup that would last for less than a minute and go away. This would only happen on cold starts. My engine does have the oil consumption issue, and it was down about a quart at the time, so I added oil. It didn’t get any better. In the past, I have had some noise immediately after startup that would go away after a few seconds and go away completely after a fresh oil change. Usually lower oil levels seemed to be the culprit. No issues with engine power at this time.
Over the last few weeks, the noise has persisted for longer durations to the point where I had to let it sit idling for a couple minutes before it would dissipate. It also got louder and sounded like more than one.
Yesterday the noise was sticking around longer after a cold start. I let it sit for a couple minutes and drove away with hearing a faint noise. On the way home, I noticed that the power seemed sluggish. When I stepped on the gas to let it down shift, the engine sounded very throaty as if I had an aftermarket exhaust system and definitely had reduced power. As it got to a higher RPM around 3k the engine light started flashing and I felt the misfiring. DTC code for multiple cylinder misfire. Looking a little more in depth with my scan tool showed the misfire counts all happening on 2, 4, 6, 8 (bank 2).
The weird thing is now after a cold startup, I don’t hear that same noise anymore. The engine sounds relatively nice and quiet, but I notice the idle sounds a little off as if there’s more of a pause between the V8 burble sound at the tailpipe. The engine light will flash under high loads or higher rpm and you really feel the hesitation. No black smoke, no blue smoke. Still that new throaty sound under load is there.
Brought it in my garage last night and listening underneath the car I can year a tap tap tap, but listening over the engine you don’t notice anything.
I’m planning on getting into this over the weekend, but I’m wondering where my time is best spent first. Sounds like more than a coincidence with the catalyst code on the same engine bank. Is there an easy way to check that a clogged cat is the issue? Doesn’t sound like a bad coil pack if all cylinders in that bank have some issue.
Plugs and wires were changed 15k miles ago. Truck has 115k miles. I realize there are plenty of threads about misfires, but I thought the history of this truck is rather unique for figuring out the problem. Any pointers would help.
Thanks
Thanks
