Ok. So a couple days ago my 4WD went out. I was able to go through the guide and flow charts, but still not exactly sure what is going on, and haven't had a chance to pull things apart yet. Money and time are tight right now, so looking for a little help getting to the next step.
'07 TB LT
Here's the situation. I'm only getting power to the rear wheels. No service lights. Selector switch will not stay lit on anything other than 4HI or A4WD. Attempts to go to other positions will flash and return to 4HI.
The front actuator stays engaged, as the TCCM thinks it's in 4WD, and will only make noise if I full the #8 fuse. It makes noise upon pulling it, and again upon replacing it. Lifting the front passenger tire up, leaving all others down, i get the wheel to turn and the front propshaft also turns.
I'm not getting any noise from the front while trying to go from 4 to 2, and underneath I can hear a click, followed by a low hum from what sounds like a bound encoder motor. If it was actually bound in the 4HI position as it thinks it is, I should be in 4WD and unable to go to 2HI. Since the vehicle is mechanically acting as though it is in 2HI, but electronically thinks it is in 4HI, what are the chances of it being an electrical (encoder motor failure), or internal mechanical failure (TC clutches?) I've checked the electrical circuit best I could, and have not found any signs of that being the issue.
Any thoughts?
'07 TB LT
Any thoughts?
