Just be aware that the starter relay #47 has the 12 volt positive power whenever the key is in the RUN or START position.
This power comes through fuse 36 first, then through the ignition switch, then through the Park/Neutral switch to the starter relay.
The relay is activated when the PCM receives a 12 volt signal on the yellow wire from the ignition switch, AND the PCM receives the proper authorization from the BCM to start the engine. This authorization comes from serial data communications between the PCM and BCM. This allows the PCM to then supply the ground side (not positive power) to the starter relay.
