I have a 2006 Chevrolet Trailblazer it requires DOT3 brake fluid, the only type I see in the stores is 'DOT 3 Synthetic' brake fluid. Will this cause any harm to the seals/o-rings/gaskets and/or master cylinder mixing it with the original?
Or would it be better to get the ACDelco DOT3?
Fixing to replace the brakes and most likely will need to top off/bleed the brakes.
