2005 chevy trailblazer roaring sound
10,685
:iagree: Your fan clutch is definitely stuck "on"
:iagree:
7,737
Prior On Topic Threads...
This is a Pretty Good "How-To R&R The Fan Clutch and Water Pump (IF Necessary)"
Once the Fan Clutch and Shroud are out.... there are only Four Bolts holding them together as shown in the Red Circles in both images below. The Electro-Viscous Unit has a Funky Black PVC Pipe protecting the Motor Wiring and an Electrical Connector & Funky Plastic Insert (...the Edges of it are Razor Sharp and can Cut You....) and that is a bit of a PITA to get mounted back into the Black Plastic Shroud at the Upper Right Corner, when facing the Front of the SUV... after that... Everything will be JAKE,
moscoreli
