- May 7, 2014
- 2
Ok so just recently had the fuel pump fail on me and replaced it with a new one. Started it up ran fine then I see "Service Engine Soon" and "Reduced Engine Power" when i went to give it gas i had zero throttle response, and threw me the code P1275 and P1280 both something to do with the APP sensor in the gas pedal. I replaced the gas pedal with a new GM one and still nothing has changend. I hear a weird noise from the throttlebody when I put the car into the on position. Is it worth replacing the throttle body when im not sure if that it? Or better of sending to my mechanic to have him figure it out? It all worked fine before the fuel pump stopped working.
Any suggestions would be much appreciated.
Thank you,
-Mark
Thank you,
-Mark
