2002 TB LTZ Bose rear speaker question
2002tbva
21
Richmond VA
Hello All,
A few years back my drivers side rear speaker stopped working and I replaced it with a cheap style Jenson PowerPlus 525 speaker. It worked but the sound was always really low compared to the front speakers. Well I just realized that the passenger side rear isn't working now so my question is what is a good replacement speaker I should be looking for? I don't care if I get it at WalMart or any other quick shop. Is there a certain wattage or other specification I just need to look for when getting a speaker for both sides?
I looked at the stock Bose speaker to see if there were any specifications on it that I can easily compare other models but this speaker had nothing on it except of Made In Indonesia and a model #. If I have a Bose system shouldn't the speaker at least say Bose on it with a bit more information? I've pasted some pictures for your review.
Thanks so much !
I have Bose too but I have no idea of the impedance neither. If the replacement you got is playing too low, then I would suspect the impedance you got was higher than the Bose.
I have a full setup taken out of a junker. I could try and measure the ohms with a dmm.
2002tbva
21
Richmond VA
Let me know what results you get if you ever do it.
I'm going to do some more research and i'm sure I'll find an answer somewhere.
Thanks !
May 5, 2013
434
Here are my measurements:
Mid range (rear door): 2.4 ohms
Sub (front door): 1 ohm
Tweeter (dash): 3.7 ohm
As reference, I measured a cheap 6x9 dual that said 4 ohms and I got 3.7 ohms.
So if you found something in 2 ohms it should work. I don't think 3 ohm speakers exist.
May 5, 2013
434
Whoaaa, you mean you can't believe everything you read on the internet :duh:
2002tbva
21
Richmond VA
Thanks for the information Mooseman. I'm going to head to my local audio shop after work today and purchase 2 rears which are rated at or around the 2.4 ohms you stated and hopefully I get some sound back.
Thanks again !!
BB07 Envoy
