NEED HELP 2002 TB LS 4WD front wheels not engaging
moneymike
4
Buffalo, NY
Hey guys, been reading through a bunch of posts and articles about front wheels not engaging when 4Hi is selected and what I'm thinking might be that the front axle disconnect might need rebuilding. If anyone could offer me advice or any knowledge on this matter I'd appreciate it. What I've done so far is confirm that the encoder motor on the transfer case is working, because when I put the switch in 4hi I cannot spin the driveshaft. However, the front wheels will spin freely without the driveshaft spinning. Went and put a known working front axle disconnect actuator from a GMC Envoy on and can hear it and took it off while plugged in and could see it moving when 4hi is selected. When I put the switch into 4Lo the rear end is at 4lo speeds but again, no movement at the front wheels. I would appreciate it if anyone else has an opinion on what it might be
Edited to add: no service 4wd lights on and when selecting 4hi the switch will blink, you can hear the whirring and the motor and the light will stay solid on 4hi but not be driving the front wheels
moneymike
4
Buffalo, NY
TJBaker57
2,906
Colorado
If I spin just one wheel, it will only be that wheel that spins and driveshaft doesn't spin either, so yes you are correct
OK then that is indeed a failed disconnect. If the opposite front wheel was to spin the other direction that would perfectly normal behaviour. Just wanted to be sure you didn't go through the hassle of taking out a disconnect that was OK!!
TJBaker57
2,906
Colorado
What happened to my 2002 was an internal thrust washer inside the disconnect wore down and coupled with a worn output shaft bearing it slipped out of position and prevented the movement of the shift collar/gear. The actuator would travel its' full distance and indicate to the tccm that it was engaged but in fact all it did was compress the spring inside the actuator mechanism and the shifting fork never moved due to the blockage!!
Here is the washer
And if you look very closely at the base of the extended cylinder here you can make out a single coil of the spring inside the extending actuator...1416091993372.jpg
moneymike
4
Buffalo, NY
well that's better news to hear.. although it could still be something in the front diff? Im planning on swapping the known working disconnect assembly in the next day or two and hoping it clears it up, but if not I'm looking at diff problems or damaged splines right?
Here is the washer
And if you look very closely at the base of the extended cylinder here you can make out a single coil of the spring inside the extending actuator...View attachment 91786
looks like you probably experienced and fixed what my problem is.. thank you for your help and I'll definitely write back and let you know if the swap fixes it
nadmak
