194 marker lights.
Rubberman
Are the front marker lights(2) and the license plate lights(2)
the only 194 bulbs for the outside lights? thought about getting these for the clearance and license bulbs
[EBAY]260954516482[/EBAY]
This site should help out a ton :thumbsup:
Lamp Replacement Guide Home
But for the outside lights yes those are the only ones that are 194 I believe
I personally would recommend getting SMD LED's! I got a pair of those for my license plate and they are awesome!! Much brighter and will last you!
Here is what I got
[EBAY]150739748136[/EBAY]
Corners
[EBAY]190639002898[/EBAY]
License plate
[EBAY]260811916615[/EBAY]
For the corners, do you want amber or white ? i thought the lens was amber?
Stock lenses for the 'side markers' and mirror turn signals are amber. If you have an amber lens, you want to put an amber LED behind it. If you have the clear lenses, you can put either a white (for true clear corners) or amber (for amber corners, obviously), depending on the look you're going for.
With LED's you want to match the bulb color to the lens color. With clear lenses you can use colored LED's to get your color.
Kobalevsky
