I did the valve cover, cam sensor, actuator solenoid, ignition coil,plugs. Check light came on and then stall.
First code was p0171 (I think) lean bank 1...crank no start...checked checked fuel at fuel rail valve...good...no pressure check though. .then after awhile with no codes it came back with p1684 I think. ..car is still down the way....ignition issue code...
