Hello, and thank you for this very informative forum.
Last week I bought an 03 Trailblazer, I6, 2wd with 155K miles on it. The truck hadn't had the best of maintenance over the years. When I bought it, it had a slight exhaust leak, a dead miss (sounds like 2 dead cylinders) and the exhaust smelled very rich.
Last night I ran a scan,
P0107
P0300
P0014
Today I pulled the CPAS, it was clogged, I replaced it with a new unit from a GM dealer.
I also installed new 41-103's (all 6 looked normal with slight deposits, #4 was cleaner than most) and inspected the coils and boots. (3 coils were original delco units, 3 were newer aftermarket). I also removed and cleaned the throttle body (with the battery disconnected) it was pretty bad as well.
Got it all back together and no real change in the way it ran. The miss, lack of power and smell were still there.
Re scanned it and P0300 and P0014 were still listed?
Next step removing coil wires one at a time, then a compression test.
Its worse at idle, seems to smooth out as the load decreases. I suspect the motor mounts are adding to the feel at idle. The exhaust leak is at the flange, so a doughnut gasket should fix that.
Any thoughts or advise? I'm new to this platform.
Thanks!
P0107
P0300
P0014
Thanks!
