I'm having similar problems with my 2007 Trailblazer LT.
Responses to Roadie's Questions:
1. All the lights on the selector switch come on at start up and then go away right away.
2. The service 4wd light is on and will not go away.
3. The switch is completely dark except when at start up.
I replaced the switch recently hoping it was an easy fix there but that did not change anything. I'm wondering if I could have possibly installed it incorrectly? I just unplugged the old and plugged in the new one? Is there more to this process that I'm unaware of?
I checked the #8 fuse under the hood and the #48 fuse under the rear seat, both are good and resetting those did not change anything. I've tried holding the switch in 4hi for 10 seconds with the key in the on position but that also resulted in no change.
Any ideas? Am I looking at needing to replace the TCCM? I don't want to go through all that and still have no change. I'm wondering if when the battery was drained by my wife recently and then having to replace it created any issues. Thanks!
