CaptainXL said:
Welcome! Sounds like your in the dark. Check and change all these fluids before making any jumps to other conclusions. They are supposed to be done ever 50,000 miles. Very well could be you have no fluid in the rear diff. If it's low then I would check the rear wheel axle seals for leakage.
Yeah, i know they are supposed to be done every 50K, but i didnt own it until 80k so not for sure if anything had ever been done before me.
STLtrailbSS said:
don't isolate to the rear sound travels i was dead set on rear diff about 2 weeks ago, spent about $300 doing early maintenance and swapping parts. Front wheel hub & new brake motive rotors...sound gone no where near the back. you can check your diff fluid with a 3/8 ratchet pull the plug and stick your pinky in you should feel fluid. also this might sound crazy whining noises have been made from the tensioner pulley up front as well. Best way is to take your time jack it up and see if you can create that noise even if in a faint way. Its hard to go off a noise and explain it over the internet I know the feeling lol
I doubt it is the tensioner. Like i said, it only happens when the car is moving certain speeds. Cant seem to replicate the sound in the driveway...I firmly believe it is in the rear because I have actually ridden in the back a few times and it is definitely louder back there than the front.
Simon01 said:
If it whines when you're on the gas but goes away when you let off the gas, definitely sounds like a rear diff noise to me. All rear ends will have a certain amount of whine in them. My pickup went through 3 rear ends before they finally got the pattern correct. It used to whine at 45MPH, but with the last ring & pinion, it will whine around 70 because they added a shim to adjust the contact pattern.
It's not neccessarily a bearing. Has it done it all the time, since new?
Probably wouldn't hurt to pull the cover and replace the fluid. Try to see if there is any metal material in the fluid. Just make sure the fill plug comes out before you drain it.
Okay, I think you are on the right tract. What exactly is the pattern, or contact pattern? Im assuming it is how the gears line up inside of the diff? Im not sure if it has done it all the time, but it has definitely done it since I have got the car. Im sure it didnt do it since new, because my grandfather is the type of person who would have it looked at by the dealer right away if it was making a weird noise...me, not so much....
Can someone walk me through changing the fluids? Is it as easy as it seems, just remove the bolts that hold the cover on and let it drain? I have seen a video from one of the members...May03SLT or something like that on youtube, doesnt seem to difficult...get it *diff*icult...lol wordplay. I have never seen a leak from the rear diff, so will i need to replace the gasket as well? What about using silicone? Does that need to be used? I know your supposed to wipe it out and any metal shavings from the magnet or something, then replace cover and fill to bottom of threads on top fill. Also, I know it is a GM fluid or something that is only supposed to be used in there, can someone tell me the name of it again? Am I supposed to use it in the front diff as well? Okay, ill take a break thats alot of questions. Any other input on culprits would be great as well! Thanks, love this forum. I have some other repairs/projects I need to tackle (as soon as I graduate college *2 months* so the car has been kind of neglected since I started, but cant wait to get greasy again!
