Won't start
northcreek
3,324
WNY
Sometimes disconnecting the battery for a few minutes and reconnecting works.
7,786
Welcome to GMT Nation...
Start with The Basics... Use a Bright Flashlight and THIS information for Checking for any Burnt Fuses:
Make certain to also pull up the Left Rear Passenger Seat and open the Second Fuse Box to check all of those as well. Using a Lighted Probe should speed up the process...
...but PULL any of the Fuses that may be suspect and Eye Ball them to make SURE.
northcreek
3,324
WNY
The CEL might normally be on if the engine is not running. Check all of your fuses.
kw1hf
10
Aurora Oregon
Thank You! I will check this out tomorrow since it is dark outside now
What terminal did you use to jump the other vehicle? If you used one of those at the megafuse, you probably blew it.
Blown megafuse after jumpstart or boost
Use only the battery terminals when boosting or getting boosted.
And if that's not it, then we have a thread with info for that:
Cranks but won't start
kw1hf
10
Aurora Oregon
I can hear the fuel pump run and shut off when I turn the key on so more than likely it is not the problem, but spark would be
7,786
This is encouraging... it means that the PCM is still responding and probably was NOT Damaged by any Voltage Spikes. Fingers Crossed.
Did you check the fuses? There is one specifically for the ignition coils.
Check fuses and fuel pump relay. Should be easy enough to troubleshoot as a crank no start.
7,786
Take a Dead Blow Hammer and Lightly *Bang* underneath the Plastic Fuel Tank ... then Turn the Ignition Key ON and see if the Engine Starts.
If some of the Commutators in the Fuel Pump have a 'Dead Spot', sometimes, this sort of jostling can allow for it to operate once the Engine is running and the Fuel Pump gets going. If this Odd Technique works... Replacement of the Fuel Pump with ONLY a Bosch, Delphi or ACDelco OEM Quality Fuel Pump is in order.
The attached image shows what a Properly Functioning Fuel Pump "Good Known Wave Form" SHOULD look like when viewed on an Oscilloscope using a Current Loop plugged into the slot for the Fuel Pump Fuse and encircled with a Low Amp Clamp hooked into an inexpensive PICO-Scope Model #2204A Oscilloscope. When viewed either on a Windows 10 Tablet or a Laptop Computer using the FREE PICO-Scope Software as "Voltage Over Time"... it SHOULD Look Like THIS:
GOODKNOWNFUELPUMPWAVEFORM.jpg.
The symmetrical Peaks & Valleys displayed here are the repeated cycles of the Pump Commutator Brush - to - Copper Contact Oscillations from the Core of the Fuel Pump. If there are any Breaks in this Even, Jagged Line... THAT artifact it is proof that the Fuel Pump is Failing. Take note that normally, the RPM of the Pump is also displayed in the lower right hand corner of the PICO Software screen... but is out of view in this foreshortened image.
As mentioned by @Mooseman ... When checking Fuses Under the Hood AND Under the Rear Driver's Side Passenger Seat Fuse Box... THIS Tool is your Very Best Friend:
Joe102938
