Wiring up light bar
Me007gold
1,106
I am trying to wire up my light bar, using this 'diagram', the only problem is my lights do not have a ground wire coming out ot them, they only have a power wire. They are just cheap lights I picked up a while ago. So how can I wire them up if there is no ground?
OffRoad TB - View topic - DIY: Offroad Roof Light Bar
I would imagine they are grounded inside themselves, just to the housing. Depending on the power of the lights, it may be adequate, but you might be able to use a self tapper and att a ground right to housing to ensure a good connection. I wonder how much light those with really put out if they dont require a solid ground?
DJones
701
St. Petersburg, Florida
As long as their ground attaches to the mounting bolt, you could run a wire to the mounting bar as long as it is metal.
Trailshaman
105
just add a ground wire to the screww holding the bulb in thats how mine are grounded
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
As DJones said, they are using the case for the ground and it should get its ground from the mounting point. You can run your ground wire to the light bar and it should work fine.
Me007gold
1,106
So basicly, put a ground wire one the bottom of the light housing, and attach the other end to the bottom of the light bar?
DJones
701
If the bar and all mounting hardware is metal, then all you should need is a ground wire from the light bar going to vehicle ground. I used 2 10awg wires on an aluminum bar, and was running 400 watts through it without problems.
groundshock
This is dead on. I'd probably sand the mounting area on the bar a little to ensure a nice, clean ground, install the lights and put a ground from the bar to the relay or vehicle depending on convenience.
You can paint it and pretty it up after. Make sure the grounds are metal-to-metal.
Samsen
