NEED HELP Wiring diagram & pinout chart .
D.L.G.
1
Tucson Az.
I need wiring diagram for gmc envoy 4.2 2004 had pack rat attack they ate a lot of wiring I've been able to repair almost all what I need is a diagram that shows censor wiring and pinout I have been able to get it runing showing code p0335 think I need to rewire rank censor
7,769
Welcome to GMT Nation…
Visit THIS Thread to Download your particular version of the GM Digital OEM Service Manuals:
Please use Caution when handling anything damaged by Rodents as per the suggestions made in these Threads:
https://gmtnation.com/forums/threads/are-rodents-chewing-on-your-gm-vehicles-wiring.22650/
https://gmtnation.com/forums/threads/crank-no-start.22388/
Courtesy @Realism ‘s Epic Thread … The Ground Locations (Post #1) for GMT360 Vehicles:
https://gmtnation.com/forums/threads/electrical-ground-locations.15491/
...and here is a Thread about the BCM and PCM Pin-Outs (Post #4):
https://gmtnation.com/forums/threads/bcm-pinout.16994/
Don’t forget to work your Under-Hood Fuse Box with a Lighted Test Probe to eliminate most of the Circuits NOT affected by any damaged wiring. Any Loss of Continuity will help with pinpointing certain Circuits, Wire Bundles and Harnesses and Plastic Weather-Pack Connectors that might have become "Snacks for Mice".
Last But Not Least... Regarding the P0335 Code... THIS Thread includes information from @Mooseman that touches upon the subject:
evenson1
