So I've been having a hum while driving starting at about 15 mph and like most people I assumed it was the wheel hubs starting to go. Got it up and taken apart, but when I spin the hub with everything off, it doesn't spin super freely and is making a metal on metal sound towards the axel disconnect housing I believe. I took a video to show what it sounds like. Does this sound like an axel disco housing bearing? If so, how hard are they to replace?
I also noticed after I took off the passenger side that the lower CV boot was totally torn, so I'm going to need to replace both axle's. Is there any chance this would cause the humming?
And last but not least, does anyone have a good way to unseize a seized caliper slide? I really don't want to replace the whole caliper and deal with bleeding if I don't have to since I have minimal tools here.
Here's the video with the sound: Front axle noise
Also, here's the gd torn boot.
Bit of an insane question, I only paid 800 for this car. Is it possible to easily make it RWD only without the front axles? I'm going to be purchasing an new car in the next few months. I just moved to michigan and this was all I could afford until I got a job. I found the thread below. Is it workable to just remove the CV Axles and plug the hole somehow? I don't *need* 4WD here. I only have a few mile commute to work and it's on a main road. It's helpful, but I can go without it.
NEED HELP - Front wheel bearing or CV?
Since i first got my TB there has been the horrid shearing sound from the front left wheel area. It sounds like it wpuld be a wheel bearing, but the guy i bought it from said it's the C.V. axle and I've never heard a C.V. make this noise. Does anybody have insight for me?
gmtnation.com
