What Diff fluid does everyone run?
CruzinQueen
46
Okay - I'm planning to change my fluids very soon since the lift has been installed and the truck has 76K on him. I understand that the only T-Case fluid to run is the GM stuff, but I've been researching the gear oils and not found a difinitive answer. I'm torn between Lucas, Royal Purple, and Mobil I. I do not plan on having to change this for another 5 years or so, therefore money is not a concern. I want the absolute best for my vehicle. What do you all recommend?
fishguy1123
310
I just switched out to Mobile 1. Not sure if it's the "best" but I think I'll be happy with it. If you don't have a suction pump for gear oil, get one! Only 11 or 12 bucks and makes the job soooo much easier and faster.
STLtrailbSS
In the SS I will be running Royal Purple 75w-90. I put a lot of strain on my diff and royal has the friction additive which is recomended for many differentials. I have found that if not running royal purple a lot of guys will buy the acdelco modifier to run in there diffs outside of GM cars.
jbones
658
I put Mobil 1 Syn LS 75wx90 in the front and Valoline full Syn LS 75wx90 in the rear.
And yes, you are correct, us the the GM Performance Auto Trak II Transfer Case Fluid only.
davenay67
217
Most, if not all, synthetics have the friction additive required for diffs. Even if you run a non-synthetic diff oil you still need to add the additive if you want your diff to last.
I run Mobil 1 75W90 in the TB and Royal Purple 75W140 (if was a steal of a deal, will use Mobil 1 next time) in my Jeep TJ. Some of the gurus on the Jeep forum recommend the non-synth plus the limited slip gear oil additive in preference to synth, something about the synth expanding more with heat..??
davenay67 said:
...Some of the gurus on the Jeep forum recommend the non-synth plus the limited slip gear oil additive in preference to synth, something about the synth expanding more with heat..??
I don't see any reason to take a Jeep forum member's recommendation over our own Owner's and Shop Manuals recommendation for full synthetic 75W90. I use Mobil 1 75W90LS because it's the same price here as the non-LS additive stuff if the store even offers a choice, and the clutch packs in the G80 locker have been reported to run quieter in some cases with the LS additive. Although the G80 is not a true LS diff, the clutch packs used to activate the locking pawls can benefit from the additive. Although the 2004 shop manual makes no mention of needing it.
davenay67
217
I wasn't implying that you should, it was merely informational to show that the LS additive is the important ingredient in the fluid. If you note, I personally run full synthetic in both of my vehicles diffs.
FWIW....the Jeep rear diff scares me a lot more than the TB rear diff, but the IS junk at the front of the TB scares me even more than the front diff in the Jeep.
navigator
504
my 06 manual only lists the additive for the SS.
I just run Royal Purple.
MY auto store only had one bottle of the Mobile-1 so they gave me the RP for the same price.
STLtrailbSS
thats a steal!!!! lol very nice
Wooluf1952
2,663
Milwaukee, Wisconsin
jham said:
I am running royal purple in my diff on a side note when it gets below 10 here my locker stays locked till the fluid gets warmed up
Does that just start happening when you changed to RP?
That doesn't seem to be a great endorsement for RP. :twocents:
Voymom
2,523
If your not planning on repeating this procedure again for another 5yrs, I would suggest just going with the GM stuff. It's expensive yes, but like you said money should not be an issue since it isn't a regular thing that needs done. I plan on using the GM stuff when I do mine this spring. :twocents:
barron03
960
I use Mobil 1 LS 75w-140 in the front and rear diff .
That's essentially rewarding GM for their rip-off parts counter list prices. $35/bottle LIST?!? :eek: And here I thought you were an enthusiast. :rolleyes:
It's not always about the price - it's about the principle. :yes:
:raspberry:
Juicy K
433
Indianapolis, Indiana
I am running Royal Purple Front and Rear, the old fluids were really dirty, who knows if they were ever changed the first 102,000 miles of its life, but It may be my mind but it seemed to drive a little smoother after replacing the fluids. And BTW I know what a difference changing very old dirty Auto Trac II can make. It was amazing after I switched that one out. :biggrin:
Voymom
2,523
:raspberry:
Yes, but so is buying their trucks :wink:
I run Mobile One, but need to figure ouot what to run with the new LockRight going in. I was told to avoid the LS additive stuff, but cant find real info to back that up.
GregT
58
Mobile 1 here :thumbsup:
Iahawkeye
52
That is what I use too.
I have been looking for the last 1/2 hour to try and find a maintinance schedule for the differentials. How often should you change them? I changed them at 75,000 the first time but I can't seem to find the schedule anywhere.
Thanks.
Wooluf1952
2,663
Thanks.
I've never found a schedule for the diffs either.
The only thing the manual calls for is checking the level and topping up as needed.
A lot of the off roaders and the guys that do a lot of towing, change at 50k.
Tofer76
148
MAY03LT said:
That's what I use.:yes:
as do i
i will just do the front, rear, and trans case every 2 years . hell it dont cost that much over all
I do it every 50K or whenever I change axles, whichever comes first. :rotfl:
Normal street drivers can justify 100K IMHO. It is very unusual that GM doesn't publish a mileage interval, yet some dealers nag their victim/owners to get it done every 25-50K. Greedy criminals. :mad:
Iahawkeye
52
So it appears that 75,000 miles may be a happy medium for a family hauler. Thanks for your input.
Taz6056
49
+1 For Royal Purple. Quieted a chattered in the rear diff I didn't even know I had. Haha, so well in fact, my girlfriend, after helping me change the transfer case and both diff fluids gushed about how nice the ride, and wanted us to change the transfer case and diff fluids in her Hyundai elantra hahahahahahahaha.
Just put Lucas synthetic in front diff
seanpooh
461
Royal Purple for me. It's in both the front and rear differentials. I change the front more often than the back since the front fluid turns darker faster than usual. The rear stays full and purple. No set mileage on change though. I do check regularly. Transfer case is 50,000 with the Autotrak blue stuff. I also have RP in both my tranny (not purple) and engine. A very good fluid overall.
Probably not since we stay with what's recommended, 75w90. I would imagine higher viscosity would lower MPG's but shouldn't be that much.
Daniel644
582
Mobil 1 full synthetic in the weight the manual calls for, did it last year sometime, and plan to do it ever 50k like it calls for, but it's just a daily driver for me, barely use the 4wd unless I get stuck in the driveway at the house I'm moving out of or hit some snow.
What would be the point of going to a thicker gear oil than what is called for?
dkvasnicka
366
Czech republic, Europe
I've heard some people do it for added protection on trucks that tow/haul a lot. I plan to do it to hopefully silence my rear diff, which developed a slight howl in specific scenarios and under moderate acceleration. It all started after I changed the oil in it after purchase (and probably 90k miles without change)... I must confess that I probably contributed to it myself because I was an idiot and didn't check for potential difference in capacity for the G86 and I just went by the instructions available for those with open diffs (I didn't fill it to the top, I just checked the level with a ziptie and it seemed enough, i.e. within 1 cm from the fill hole - I know it's stupid)... Long story short, I was running the diff with 0.85 qt less fluid than it needs for some time, like 2500 miles :bonk: I don't believe this is all it took and I think the diff was already on its way but I can be easily convinced otherwise :wink: I hope to know more once I open it and see the fluid and the magnet. I guess bearings are waving me goodbye or something.
Reactions: littleblazer
littleblazer
9,265
I've heard some people do it for added protection on trucks that tow/haul a lot. I plan to do it to hopefully silence my rear diff, which developed a slight howl in specific scenarios and under moderate acceleration. It all started after I changed the oil in it after purchase (and probably 90k miles without change)... I must confess that I probably contributed to it myself because I was an idiot and didn't check for potential difference in capacity for the G86 and I just went by the instructions available for those with open diffs (I didn't fill it to the top, I just checked the level with a ziptie and it seemed enough, i.e. within 0.1 cm from the fill hole - I know it's stupid)... Long story short, I was running the diff with 0.85 qt less fluid than it needs for some time, like 2500 miles :bonk: I don't believe this is all it took and I think the diff was already on its way but I can be easily convinced otherwise :wink: I hope to know more once I open it and see the fluid and the magnet. I guess bearings are waving me goodbye or something.
Buddy of mine said GM used to not quite fill them up all the way from the factory, used to do like 3/4 full. If that is true or not I don't know. I do know the sierra spent most of its life on the factory change and it was allegedly 1 quart low. I dunno.
As far as I know full is to the bottom of the fill hole. You can't fill it more than that because, well, it runs out the fill hole :tongue:
triz
746
Yeah it should pour right out the fill hole. I am using the Severe Gear fluid as well from Amsoil.
dkvasnicka
366
I'd love all that to be true because it would enable me to shift the larger portion of the blame for my problems to the fact that the diff had not been serviced properly before I bought it :wink:
memoremix
