NEED HELP Tb SS transmission replacement.
xavierny25
6,324
Staten Island, N.Y
Hey guys along with all the other crap I got going on my brother-in-law calls me this morning that his tranny went out on him last night. He had it towed to his house and now we are on the hunt for a rebuilt tranny.
I'll be doing the replacement myself along with him and his brother. I just need as much info before I can dig into this and what else I might need to upgrade/replace while I'm under there.
Any and all info you guys can come up with to help would be much appreciated.
Truck info: 2008 Chevy trailblazer SS awd 75000 miles.
Make sure that transfer case has fresh fluid as well...its only 50K intervals for that stuff.
Might see if he wants a better stall in the Torque Converter while its apart. Few bucks, but a nice upgrade
An aux trans cooler would be a good idea, and pretty necessary if you play with the stall as those can add a lot of extra heat.
xavierny25
6,324
Staten Island, N.Y
I got a pdf file on the R&R over on tbssowners.com . I'm looking for some pic's and or videos on the how to now.
Reprise
2,724
FYI - There's a 20 part video on YT called 'Project 4L60e' (10 teardown, 10 rebuild)
I know you have the 4l80, but there are supposed to be many similarities between the two. I watched some of those vids a few times when I was putting in my shift kit; found there were things mentioned there I didn't see anywhere else.
Good luck, and post a thead on the R&R if you get a chance!
If I'm not mistaken, SS have the 4L70E. Might be harder to actually find a rebuilt of these so if you don't rebuild it yourself, you likely have to get yours rebuilt. It would be a good time to get all beefed up parts, shift kit and such.
Reactions: Tiggerr
Reprise
2,724
4L70E is a 4L60E with some factory upgraded parts. Same guts basically however.
4L80E is a much bigger (and stronger) beast. Can be almost bolt-in for a RWD, but for AWD with that transfer case I'm not sure the options you'd have.
xavierny25
6,324
Staten Island, N.Y
If the truck was mine I'd do the swap to a 4L80E and make it RWD. It would be alot more work but worth it in the fun factor.
Reactions: Tiggerr
littleblazer
9,265
The gearing on the 4l70 is better than the 80 though. 80 starts deeper and ends shallower iirc. But I'm sure that can all be changed.
I've seen something on a 4L60E to 4L80E swap and it's apparently not that easy. IIRC, wiring and TCM programming is different.
xavierny25
6,324
Staten Island, N.Y
Well after taking it down decided to have the transfer case rebuilt. Sure enough it needed. I also checked thing out in the diffs and the front passenger side disconnect was stripped along with the intermediate shaft. Along with a car rental we are about 4500 in the hole. And the truck is still in pieces. Oh man am I going have a few things to say in the FY thread. 75000 miles smh I never would of thought of all this.
Intermediate shaft stripped?
Ouch, that doesn't happen that often.
xavierny25
6,324
Staten Island, N.Y
Yea tell me about it. I've heard about the axle side strip and go to ish but never the inner side of the diconnect. I already ordered the upgrade along with the what from uspowertrain.
On another note does anyone have a part number for the rubber seal from the FRONT drive shaft to the transfer case. It's really been driving me nuts cause I haven't even seen it in any pic's I've looked up in the interwebs.
EDIT
I'd be looking at changing it into a 2wd since you have to pull the tranny anyway. Can't be cheap to rebuild the full-time Torsen TC.
A couple of other guys had their shaft strip so it's not unheard of. Not sure if it's a result of the disco failing though.
Edit: Man am I slow! You replied before I finished this reply.
Reactions: Tiggerr
Tiggerr
1,324
Perrysburg, OH
Sound like someone was beating on that thing just a bit! 75K?! Damn!
I'm with Mooseman on this one 2WD it..less weight and drag, WAY cheaper!
xavierny25
6,324
Staten Island, N.Y
Transmission is already out and at the speed shop. Transfer case cost close to 700 to rebuild and is at the speed shop aswell. Transmission is getting a rebuild aswell but there just tearing into it so I don't have a final price on it.
It's not my truck and my brother-in-law wants to keep it as close to the stock setup as possible. Aside from any improvement parts I don't think he would want to do anything right now. Believe me I've tried.
Reprise
2,724
I'd agree - looks to me like the BIL likes to get on it. Have him take a look at the oil pickup relocation kits for the SS - the stocker is in the front of the pan, and with the hole in the pan midships, the engine can suffer from cavitation / oil starvation, especially with people who channel their inner Dale Jr.
Since he's in for over $4K now, and the truck is down, I'd relocate that pickup tube now (and maybe see what things look like w/ the motor at this point)
Reactions: Tiggerr
xavierny25
6,324
Staten Island, N.Y
We are pretty much in over our heads with this because of time. He's got to be on the road Friday morning to head to Maryland. We should have everything back together by Wednesday. Fingers crossed and pray for us.
Here's that funky rubber seal I'm talking about if any one has any idea as to a part # or what it is I should be searching for.
xavierny25
6,324
Staten Island, N.Y
How it sit now after we brought it down some till we get everything we need. We have about 8 jack stands all the way around holding up stuff.
Driveway mechanics. Always fun (not!). And the wife is pissed about destroying ours with oil and stuff.
xavierny25
6,324
Staten Island, N.Y
We gotta do what we gotta do to save a buck or 2. Nothing has been at all to uncomfortable to do. I'll let you guys know what we brake putting it all back together. So far so good on keeping the cement tire paths clean. Lol.
chriswilson5585
