stormyday said:I picked up an 02 trailblazer the other day with squeaky brakes
CaptainXL said:Do you mean squeaky as in "creaking" like an old rusty door hinge? Or do you mean squeal like a high pitched metal on metal scrapping?
If you really have creaking and the pads and rotors look ok then I have some news for you. I just went through this ordeal. The funny thing is GM knows about it. Let me know exactly what you got and I can help. But there have been some good suggestions thusfar.
triz said:Don't want to jack the thread but I have a high pitched sound that goes away when I apply the brakes. I havent checked it out yet but I was going to relube the pins. ??? The sounds comes back when I drive and only goes away when your on the brake.
CaptainXL said:That's the brake pad wear indicators. When you apply the brakes the caliper pushes the indicators further into the rotor, along with the brake pad. It doesn't vibrate and make the noise when you brake. Sounds like you need a major brake job. I would also clean, inspect the calipers and rebuild/replace if necessary. If doing the work yourself I would invest in the following.
Amazon.com: ACDelco 18K1551X Professional Durastop Front Brake Caliper Kit: Automotive
HARDTRAILZ said:Used motor oil will take away the squeaking...
