Replace 4l60e with 4l70e?
DenaliHD66
Can this be a direct fit replacement should my 4l60e finally decide to crap out someday? 4l70e can handle more power so I've read... any thoughts?
Bartonmd
545
From what I gather, the 4L65E and 4L70E are just a 4L60E with the upgraded internal parts that most 4L60E hop-up rebuilds do, anyway... They are both uncommon enough that you may just want to rebuild your 4L60E with all the good parts, and make it as strong or stronger than a 4L70E.
Mike
ScarabEpic22
728
Same trans when it comes down to it, the 65E variant has things like 5 pinion planetarys and a few other parts "beefed up" compared to the 60E. The 70E basically adds an ISS (Input Speed Sensor) and maybe a few other tweaks, but its not much different than a 65E.
Much better off buying a built 60E and being done with it, if you're junkyard shopping then it really doesnt matter. Remember, even though they share the same RPO code, I6 and 5.3L 4L60Es have different valve bodies and torque converters...
DenaliHD66
Yeah I figured they were mostly identical except for how much load they can take. I wish I had a trans temp gauge... and I've thought about installing a tranny cooler from pcm4less, even though I don't tow or off road much anymore with it.
SAR85
74
Have you thought about using a ScanGuage II or using another OBDii reader to read trans temp? I know many members use the ScanGuage and I use Torque on Android and it works very well. These also allow you to read other data that is not visible on the dashboard.
DenaliHD66
No idea what any of that is. Also I don't have a smartphone so I am behind the "times" on electronics.
Love my Scanguage! I needed a trans cooler and it does keep it much cooler.
SAR85
74
Without a smartphone, it looks like a ScanGuage or other stand-alone device is the choice for you. I think there may be one or two other options (Dash hawk maybe) but I'm not sure of their exact capabilities.
DenaliHD66
Sweet. Does this plug into the port under the steering wheel? Any suggestions for which model to get? I want it to be universal for a variety of vehicles...
SAR85
74
I don't have any personal experience with anything other than Torque on my phone (other than handheld scan tools) but I know many members here use the ScanGauge II, which allows additional PIDs (such as trans temp and oil life percent remaining) to be programmed in so they can be read. Here is a link: ScanGaugeII : Linear Logic - Home of the ScanGauge. The basic functionality (read/clear codes, basic engine data) should be able to work with any OBDii compliant vehicle, but trans temp and the other "X-Gauges" may not work with as many vehicles.
Hopefully members who own that tool will be able to answer additional questions that the website doesn't!
On a side note, I just realized I've been misspelling "gauge" in my previous posts in this thread...oops.
Yes it plugs into that port. I believe there is a thread on where people have the scangauge mounted as well.
I have the Scangauge II and it does all I need.
EDIT-- http://gmtnation.com/f23/how-did-you-mount-your-scangaugeii-2549/
DenaliHD66
I don't have a DIC, but this gauge will be able to read my trans temp? Assuming my transmission already has something built in to keep track of that?
ScarabEpic22
728
Yes, the scanguage will be able to report any information the PCM/ECM/TCM sends over the databus. All 4L60/65/70Es have temp senders in them, the PCM or TCM uses that information to increase line pressures when the trans fluid is cold and make sure it doesnt overheat.
kraymates
