- Dec 5, 2011
- 597
My '06 needs a SAI pump, and while the cost of the pump isn't cheap, its also not too bad, looks like I can get one around $100. My bigger concern is these trucks tendency to devour SAI systems. I've had the valve replaced twice and now the pump is dead. Meanwhile, the SAI system isn't even necessary. I was looking at ShortBus's TB at the midwest meet, and realized his '06 LS does not have the system at all. This of course made me wonder, did they actually make a separate exhaust manifold, and the answer is no, they didn't. There is a block bolted in place where the valve should be, and his air box doesn't have the hoses for the SAI system. So here's the question.
I am considering removing the valve, and the pump, installing the block in place of the valve, and having the codes related to the SAI turned off by PCM4Less. Any thoughts. This would cost about the same as fixing it, but it would permanent.
