- Sep 15, 2012
- 18
ok so i went to get my rear diff fluid changed and the guy said there is a leak coming from where the drive shaft goes into the rear diff. i know its just a bearing seal leak. but its been a while and i just asked to service the whole rear diff and replace the broken parts and clean out the diff. now i like the G80, but i dont want to have to go through all this crap again later on down the line. so i started thinking what would be my options for a new locking diff and this is what i came up with.
1. another new G80.??? not really wanting that.
2. a new air locker diff from arb. can be expensive and needs a new rear end. so no.
3. i found this on eaton.com. its called the eaton Elocker. have you heard of this??????
Performance Products | Eaton ELocker
Eaton Torque Control Products 19659-010 - Eaton Electronic ELocker Differentials - Application - SummitRacing.com
(IF YOU CLICK ON THE OVERVIEW OF THE LOCKER IS TELLS YOU WHAT BEARINGS YOU NEED)
here are the specs i found on the eaton e locker:
gm 8.5 inch/gm 8.6inch
10 bolt pattern
for use with 30 spline axles
for use with 2.73 and up gears
needed for proper install new bearings (part#LM-603049 / part#Race LM-603012).
now my 2002 trailblazer 4x4 LTZ
all stock rear end, which means it has a 10 bolt rear end (8.6inch)
rpo code G80, which means it has the G80 diff.
it has 3.73 gears
i dont know how many splines it has though. im gussing its 30 spline.
Here is a video of how the eaton E locker works. i think youll agree that you want it.
[video=youtube_share;bnplleAycNY]http://youtu.be/bnplleAycNY[/video]
my questions is would this work for a G80 upgrade, without having to buy an entire new rear end assembly?
in other words, can i just swap out the G80 for the E locker?
10 bolt pattern
it has 3.73 gears
