These codes always haunt me. I've cleaned my throttle and maf and it didn't help. I did find a vacuum leak before on the pcv system and that helped for like a week. Yesterday I also noticed the black clip on the tps connector was broken and it popped off while driving, I found a temporary fix. I was rushing this morning but my LTFT is at -15, idling. I dont get why both sides are running rich unless I somehow have 2 bad injectors which I dont see as very likely. If that connector was the problem with it not making a good connection and me "fixing it" could I just need to disconnect the battery to erase the stored fuel trims and try again. Thank you in advance.
