PCM Tune
AzTruckGuy
501
scottsdale, az
Ok so after the PCM reset with all the work I have done to the Trailblazer, I assume the PCM reset itself to GM "safe" mode, which is basically a generic setting. What are the thoughts of the group about PCM for less? I would think there has been some improvements since 2008 that a PCM tune could benefit the Trailblazer? Maybe even get better MPG?
Mounce
13,667
Tuscaloosa, AL
Everybody uses pcmofnc or limeswap.
From what I understand pcmofnc used to be named pcmforless so all of the archived info you read about them around here is technically referring to pcmofnc.
Limeswap has very competitive pricing though, as in, cheaper for pretty much the same thing.
But yes, a tune is about the only worth while / affordable performance upgrade for these rigs.
AzTruckGuy
501
scottsdale, az
Thanks for that info Limeswap is very competitive for what they offer
I used @limequat twice (I6 and V8) and Jeremy's great to work with, as well as competitive.
I used PCMofNC twice for a tune and retune after gearing and tire size changes and am completely satisfied
moscoreli
