You are correct. I installed before noon today and I went to have my typical taco lunch with my American Legion friends and she went to the store and the stop cranking with key in crank position, did it again. I need to get it to fail and stay failed so I can test at the starter and flow of power. Crap. Makes for a good video though.HI RON! .. I dont wanna pause the video right now
I guess you can click on the spoiler I posted back on page 1..
I might have been wrong.. Only time will tell!
Because it had started to rain, I had rushed out and connected the battery and should have explained in video but only did mention that it had started to rain. My girl said someone would mention that.Nice video. Apart from the video being sideways, if the battery was disconnected, why was the courtesy light on and you were able to start it right away?
We would love to see a video of what it's doing. Probably a shot of you turning the key and looking at the gauges at the same time while we also listen to what the engine/starter are doing. You can also add some commentary while doing it. I think that might help a lot. If it's intermittent though, it will be difficult to catch.
For extended start situations, on these style trucks..
I always start with a spark test. If the cam/crank correlation is off, or not reading, its a pretty easy thing to diagnose. Pull the coil, insert spark gap tool, crank engine. If extended crank is observed, did you have spark?
Yes, I have posted TWO different problems. The long crank before starting is related to fuel pressure drop when sitting for a long enough period of time. I have tested for and know I need to do fuel pump eventually.Dont bother with a new starter relay, just swap its position with a relay in the fuse box. I think most do it with the fan relay. Or go grab a handful from a junkyard.
I am really confused to be honest. Is it extended crank time? Or is it cranking then stopping? Both?
2 different scenarios that require 2 different course of diagnostics.
If its cranking, and then stopping all on its own, swap relays. If the problem continues, than I would almost think its a crank amp draw issue, and the PCM is going into integrity protection, or a voltage drop, and the PCM is doing integrity protection mode. One is starter related, the other is battery related.
If its extended cranking, than my post on page 1, at time of issue, would have to be pursued.
By this time, next week, WE will know. I am also going to do the pin drag test, as @TJBaker57 recommended
I will take a look at what you are saying later today. I do need to be clear though. When the key is moved all the way to the crank position and held there, it cranks like any normal vehicle would and has done so thru all the ignition switch changes.Your last description is making me think of this. When I had my 02, at first, it didn't have, what I call, "flick start" where you turn the key to start and release and it keeps cranking until it does start. After I got my PCM updated by the dealer to correct another issue, I discovered it now had flick start.
Fast forward to my 07, it has flick start and works as it should, however, I have a minor issue with the key. When I turn the key fast all the way to the end of travel to CRANK, it doesn't crank. But, if I let it go slowly from there, it will start to crank. And if I turn the key slowly to crank, it starts cranking just barely out of the detent for the RUN position. Either I have a misaligned ignition switch gear or there is a minor variance in the switch or key cylinder.
Try using flick start and different positions with the key to crank. Maybe yours hasn't had the update and doesn't have flick start. If yours has the same issue as my 07, maybe you're going through the motion into the CRANK until the end of travel and then stops cranking? Try stopping moving the key in the middle of travel into the CRANK position.
I have installed a Genuine GM relay a few responses back and still have the problem. When I got the rig, I had found out here about problematic ignition switches and so I did review install steps at you tube. I know I keyed the cam gear on the switch correctly, both the first time I replaced with the Standard Parts switch and recently with the AC Delco switch. Mind you, I had no problems with the switch that came with the rig when I bought it in December but I also had not had that many key cycles after the purchase, before I installed the Standard parts switch. For all I know, I was gonna have the same problem I have now, eventually, but who knows. At this point, I am tempted to spend literally less than 10 minutes and reinstall the original switch that came with the rig in December and see what happens.I got to back pedal here..
I was in in complete agreeance with you about the starter solenoid, UNTIL, you said that if you cycle the key, it works again. A faulty solenoid wouldnt do that. If it was faulty, it would stop working, until it cooled down, or whatever..
I am really leaning towards a bad relay.
But I do have a request, next time you are starting it, and it stops cranking, keep holding it in the crank position, but try to wiggle the key, and to try to turn it just a bit further. I am thinking that it may be slightly out of sequence on the ignition switch cam. But this is just a theory, but I have a basis for it.
My Rendezvous I sold a couple years ago, I had to remove the ignition key switch so I could get keys made for the truck. I replaced the ignition switch while I was in there, and I installed it 1 tooth off.. I did not know this when I did it. But... If I turned the key switch just a bit further, the truck would start. I just left it, being lazy . But I knew what had to be done, and I explained it to my wife, so she also knew, and the new owner when I sold it.
I am rooting for you that its something simpler than a starter.. If I am remembering correctly, the ones on the 4.2 are a pain in the ass to replace. Still easier than the 5.3/6.0!
Yes, I completely understand.Do keep in mind that the "detents" and the spring back from crank is all a function of the switch itself. There are no "stops" or "detents" in the cylinder/housing assembly other than the ends of the rotation. The cylinder spins freely to the extents of rotational travel, except of course for the park/lock. So regardless of where the switch/cylinder gear alignment is, a tooth of or not, the relationship between the 'RUN' position and the cam that lifts the contacts remains the same.
Up late because could not get to sleep. My girl is flying out today to Texas for a few days to see her daughter.
It has been 10 days since I repositioned the gear teeth on the ignition switch and it cranks as it should each time. I did another video about the spark plugs replacement and the ignition coil boots and springs. Since then, it fires off quicker when cranking. I am now convinced that the ignition switch gear teeth were out of alignment from day one, when we bought the Blazer in December.
