Just for reference I did replace the ignition switch that I was warned here can cause problems. I could not get an OE Genuine GM that I like to use and had to settle for a Standard Parts switch. After that replacement all has been good for 2-3 months till now. I have been chasing an intermittent long crank before start, after sitting for long periods, like overnight. I did the fuel pressure regulator with no change and if turn key to KOEO for 5 seconds and then start, there is no problems and I believe it is fuel pump related.
Is a 2002 with 70k miles on the clock.
Anyway, during that diagnosis, I ran in to another very intermittent problem. While cranking the engine will initially be spinning and then the cranking just stops and if cycle the key, it cranks ok and then starts. I fear that the new ignition switch may be a culprit but I did replace the ignition relay with Genuine GM part. Have not experienced problem since then but the vehicle has only been started 3 times since the relay and the initial problem was very intermittent. I do plan to crawl under it and inspect the starter connections as well.
So, has anyone experienced this, even after replacing the ignition switch? Thanks in advance for any help.
