- Dec 4, 2011
- 568
I'm making the rounds on various sites to see what answers I get on this, because oddly enough, it doesn't seem like this is something many people have actually done?
I am changing my gears from 3.42 to 4.10, and if I don't tell the computer (not sure if its the PCM or TCCM that handles this) about the change, everything from my speedometer to the transmission is going to be off by nearly 20%. Now obviously GM has some way of programming in which gear ratio is installed in each vehicle -- the problem is that I called my dealership and nobody there had ever done such a change before, and they had no idea how to reprogram my system without calling a GM tech line (for which they would pass on the charges to me for using this service).
I also have HPTuners available, and I was given a suggestion on changes to test after I swap the axles. This seems more like a hack than an actual correction, but I'm willing to give it a try and see what happens.
The rear axle is going in on Saturday. The front axle will follow in a week or two, depending on how ambitious I'm feeling. Any info that can be provided in the meantime for a *proper* correction would be appreciated.
