NEED HELP GMC Envoy Steering Wheel Swap
Elroy Jetson
5
United States
I have a 2004 GMC Envoy XUV 4.2L without the option of steering wheel controls. I recently purchased a steering wheel that have the options installed on the wheel. What are all of the steps to make the buttons function properly other than switching the actual steering wheel and air bag. Is it anything else that I need to aquire to make it work (as far as wiring)?
7,741
Probably can't be done right without a CRAZY amount of OEM Wire Harness & Module Swap Installation and PCM Re-Calibration Hassles. Read THIS PDF and just LOOK at all of the Extra Features accessible through the Push Button Controls mounted into the Steering Wheel that require corresponding Wiring and Acceptable Modules that may not be included in the "Plain Wrapper" Versions of the Trailblazers and Envoys Harnesses.
Take the time to Examine your own RPO Features on the Silver Sticker Pasted inside of your Glove Box to get a better understanding that there is a REASON those RPO Listings are usually generated AT THE FACTORY and they seldom if ever enjoy allowing different Features being "Added On" later as an afterthought:
If your Present Steering Wheel WORKS.. (Including the Clock Spring) ... Don't FIX It.
  • 2004_gmc_envoy_xuv_getknow.pdf
10,685
Were you able to source a replacement clock spring that has the additional wires in it for the added functions as well? I did the same swap in my 05 TB some years ago, and remember having to run wiring from the cluster down to a large harness connector at the base of the steering column, that went up to the clock spring. My other buttons were for the radio controls (I've seen some that have HVAC controls) and since I have an aftermarket head unit, ran the additional connections to an aftermarket adapter.
If you're comfortable with wiring and making connections, it won't be difficult work, just a little tedious, as wiring tends to be. :twocents:
Elroy Jetson
5
United States
Do you happen to remember or know the part that I would need to order?
Easiest is to replace the whole column, especially if you can find one at a Pick-n-pull. That's what I did. As for connecting the controls, I connected the two wires from the radio control switches directly to the Android HU as per this thread:
I also connected the cluster buttons to the cluster wires as per the schematics however this required replacing the original non-DIC cluster with a DIC cluster.
danfromutah
