Ford Pushrod Returns With The New Godzilla 7.3L OHV Big-Block
cornchip
637
What....no EcoBoost?
the-return-of-the-ford-pushrod-with-the-godzilla-7-3l-ohv-big-block-2019-02-05_22-49-15_378528-960x640.jpg
What? No cylinder deactivation? :crackup:
littleblazer
9,265
The moment you realize that overhead cams isn't as important as you thought.
No replacement for displacement now....
Reactions: northcreek
D
Deleted member 20902
I just watched that movie, Ole Ferris Bueller layed the smack down on godzilla and all the little viloso-raptors.
Reactions: Mike534x
1,000 is just a good starting point
northcreek
3,327
WNY
Yeah,1,000 hp on pump gas is a helluva start
littleblazer
9,265
Merc racing has been doing 1650 on pump for 6 years now. And they have that n/a 7.0l making 750 hp which I find significantly more impressive than boosting it...
northcreek
3,327
WNY
That is pretty impressive what Mercury has done with an IC engine. From what I'm seeing the 1650hp requires 112 octane and is also boosted.
littleblazer
9,265
I forgot they're dual cal now. It'll run 1350 on pump though which is still insane. 91 pump to boot, not even 93 which is pretty common on the water.
northcreek
3,327
WNY
Was the Genesis for these engines the ZR1 engine that Lotus engineered and Mercury built for the early 90's Vette ?
littleblazer
9,265
Kind of. Merc took what they learned from the LT-5 and made some serious modifications to it. Their engineers they have building these are some of the sharpest to ever build an engine. They did some serious tweaking to the architecture though. There isn't a lot in common but the blood line is there.
Sounds badass too
memoremix
