Hi everyone and sorry for the long post in advance.
I'm doing a few mods and upgrades on 2004 Chevrolet Trailblazer LT the latest was sound deadening the whole car which had me to remove almost everything on the floor seat, carpet and the fuse box/ECM, everything was disconnected for a while (few months) after I was done with sound deadening and carpet upholstery i started reassembling the fuse box and the shifter assembly (just note i have all the door panels removed including the DDM and PDM and both rear window switches for LED mod as well)
Since the car was parked for a couple of months i decided to start it up just check to everything is good (keep in mind i didn't plug any of door switches at this point) truck started up fine. But i did notice when i turned it off and remove the key the doors or something started locking or unlocking multiple times before it stops, it happened each time i start and turn off the truck but it no longer does that now, i plugged all the switches and both driver and passenger switches i have no power in both completely dead, rear window switches are working. Also my keyless fob is not working and the battery is good. If you open the tail gate and close it i can hear something like a latch engages but the tailgate is not locked.
I made sure all of the plugs at the rear fuse box is connected well and tested all of the fuses and all are good however i found 10A of DDM was blown but the cheap@$$ previous owner did the unthinkable and hardwired the blown feuse with a thin cooper strand!! I'm afraid it did some damage to the DDM but that doesn't explain why the PDM is not working on both sides as well when testing alongside the keyless fob i believe these are related but my knowledge is quite limited.
I would really appreciate any help or guidance on this matter.
A.
A.
