Bucking on hard acceleration from a stop ........
Blade
257
It seems that whenever I plan to turn out in traffic and go hard, I get this crazy "bucking" like I am stomping the pedal on and off. It seems to be most prevalent when I am turning out into traffic either right or left then stand on it to get moving. It's not that I do it often, however the time that I do need it to move, it seems to fail me.
Could this be related to the stabilitrack system? (In a straight line it seems to be fine) MAF? Any thoughts would be appreciated before I take it in to the shop for "diagnostics". :undecided:
4,024
Sounds like it could be the traction control kicking in. Any lights on the dash flash when it happens? As you know, it's easier to get the wheels spinning taking off from a corner than in a straight line.
Denali n DOO
5,596
Could try the same test with traction control turned off and then with traction control and stabilitrak turned off....
06Envoy
Guys, I don't know that it is traction control vs stabilitrak.
On mine at least, I could turn traction control off and I can spin the rear tires in a straight line. However with TC turned off and stabilitrak still on, try turning a corner and the bucking happens...
Only with both traction control and stabilitrak turned off can I let loose and spin tires, do spins, etc...
Could the OP turn both TC and Stabilitrak off and see what happens???
To turn off the stabilitrak, hold down the traction control button for 10 seconds until your DIC stays on STABILITRAK OFF.
Not sure if procedure is the same on the Caddy, but it could be worth while to try turning off the different systems and seeing if the problem changes.
Blade
257
I will try turning it all off. I think I tried that when I first noticed this about a year ago. I only recall seeing the TC light as the wheels chirped.
As you may know, the truck is AWD, and just an upgraded Denali.
Will investigate further with it all off and get back.
4,024
Didn't see the AWD part, I thought if was a 4X4. Plus, I was going off what my SS Commodore would do with the TC.
STLtrailbSS
Not that I would do such a thing but you need stabilitrak off to really break loose.
Blade
257
So after some experimentation it appears to solve the bucking with the traction contron and stabilitrack disabled. Are they going to say that this is normal behavior for these trucks? We shall see in a couple of weeks when I take it in.
jrSS
So is the tranny doing this or the motor? Do u have a cone filter (ex. K&n) that u oil??
Neither by the previous post. It is in the sensors and safety electronics...
jrSS
I was just saying maybe some of the recharging oil got on to the maf sensor and is fuckin with the tranny.
Possible if he had not posted what alleviated the issue already.
jrSS said:
Haha. My bad kyle. Guess I need to read more thoroughly.
Hah...i caught you skimming instead of reading...
Gdub2306
