Figure it's about time to get all my projector retrofit stuff chronicled and documented. This will also be a way for you guys to keep me honest and motivated when I start slacking. (which tends to happen way too often.)
My first retrofit got started in the spring of 2013 and consisted of the following:
4 x Morimoto Mini D2S projectors
4 x Morimoto 3Five 35W ballasts
4 x Morimoto 3Five 6000K D2S bulbs
2 x Ocular shrouds
2 x Iris shrouds
2 x 12" 5050 switchback strips
2 x 8" 5050 switchback strips
1 set of dark smoked OEM replica corner lenses
2 x 9" blue LED strips
2 x white Morimoto XB halos
For the alignment process, I chose the indoor, living room wall method. Remove the reflector bowls from the headlight housings, clamped them to a bookshelf, powered up some halogen bulbs and marked the "cutoff and step" on the opposing wall with some painters tape. After marking where the reflector bowls were mounted on the shelf for later reference, it was time to get busy with the Dremel, and enlarge the bulb openings to fit the threaded shafts of the D2S projectors through.
Note, the Morimoto Mini H1 projectors have a smaller shaft, and require minimal trimming if any. The D2S were considerable. Once the openings were large enough, it was time to install the projectors and make the necessary adjustments to align the beam patterns.
After removing them several times to shape the reflector bowl openings (the low beam projectors needed to be pointed higher, and the high beam projectors lower) I was able to get a good looking beam pattern on the wall.
2 x Ocular shrouds
2 x Iris shrouds
