- Dec 4, 2011
- 253
I finished 2 weeks of general vehicle maintenance on my "new-to-me" 08 Yukon XL Denali with 83,000 miles. The only thing that I have planned next week is a coolant flush and fill of GM's Dex-cool. Outside of that, this is what I done so far:
- Front and Rear differential fluid change
- Transfer case fluid change
- Transmission fluid and filter change including system flush using internal trans pump.
- Motor oil and filter change
- Brake fluid changed; bled through lines via calipers
- Power steering fluid changed (reservoir emptied and refilled)
- All new high performance brake rotors and original OEM pads from AC Delco
- New ACDelco 41-110 spark plugs (#8 cylinder was a PITA to access)
- New ACDelco ignition wires
- New dry air filter from AEM
- New air intact tube from Air-raid (uses existing airbox) - the 6.2L just sounds good at WOT.
- New driver's front CV axle installed (OEM ACDelco); boot was tore.
- 2 new rear OEM air-ride shocks
- Greased all zerks on front suspension
- Tires properly inflated
- Tekonsha Prodigy 3 brake controller installed
- New VCIM bluetooth-capable module installed
- New wiper blades installed
