Anyone put Ceramic Beads in their tires for balancing?
DenaliHD66
Was just recently introduced to this concept. Was wondering if they are worth using at all? I am not a heavy off-roader, but if they really do work to keep the tires balanced and maybe extend their longevity, I would be down for trying them out.
Denali n DOO
5,596
I don't know of these ceramic beads but I can say nitrogen filled tires are awesome, I have 4 summer n 4 winter tires and they haven't even lost 1/2 pound of air in three years, +30 or -20 degres and they never change.
air is 70% nitrogen :tongue: my TB only rarely needs PSI adjustment and since it is free, well, I can do that once every 6 months to a year :biggrin:
A couple of offroaders did it, and discussed it on ORTB, if I remember correctly. But it was 3-4 years back. Did you run a search? I don't personally recall who did it. Sorry. :redface:
DenaliHD66
Tried searching "ceramic beads" and got 0 results. I heard the nitrogen thing was a bit overrated. I guess I'm one of those old school people who actually periodically checks the tire pressure and adjusts it during the seasons so I don't really need to 'set it and forget it.'
ksimm92
166
I heard they also improve performance and possibly mpg because the nitrogen weighs less then air... do you know if that's true? I would be willing to give it a shot, where do you even go to get it filled with that?
DenaliHD66
Why can't we just fill them with helium? No seriously.. lol. Or hydrogen?
It's not true. Snake oil. A lie concocted by the tire industry to extract money out of the pockets of gullible consumers. Dry nitrogen has justification in racing and the aircraft industry. Not in street automobiles.
The physics has been debated here and many other forums extensively. No need to rehash it here yet again. :no:
ksimm92
166
good to know, I will look into it more. :undecided:
The beads are in use by couple still I believe. I ran some Swampers with the Airsoft beads that many offroaders use instead of the more expensive ceramic. They did ok. Not as well as traditional balancing. I would NOT recommend them to those not in need of finding a way to balance an excessively large or a used tire. The balance can be knocked off by potholes and road hazards and can induce death wobble in certain situations. The right ratio is needed and if not found, you can lose your balance in the corner and it is not regained until you slow way down. I have had direct experience with several people that have tried them and switched to trad balance methods and know some that love them and swear by em. That all said...I went with trad balance on my current tires, but if I end up finding another set of used 35s for my other wheels, I will try the beads again.
I have never seen anything about them improving the life of a tire.
There are these
Centramatic
and I would pick up a set if I had the extra money cause they could possibly the last balnce you ever got.... But I do not know anyone that has actually tried them.
fishsticks
433
Beads in the tire is an old trucker trick. It works. Some have also used golf balls with good results.
I balanced the 37s on my Yota with 11oz of .25gr Airsoft pellets in each wheel. With rock rings the tires/wheels were an easy 100lbs a piece. I just bought 40s for it and will probably put beads in them as well.
THe TB's 35s are traditionally balanced. If I ever have to dismount/remount one or more of them I will probably put beads in them. Most tire shops want more to balance one tire than it would cost me to bead all of them.
Would I do it on a 29" stock tire? Probably not.
If you do it, you will have to get used to the sound of the beads settling every time you stop.
MDBT
223
Never tried them in a car/truck tire but the "Dyna Beads" brand ones we got for my father's motorcycle worked quite well. I was surprised how small they were. They do a good job of listing the appropriate amount of beads for a particular tire size but I'm not sure how accurate those suggestions for larger truck tires.
Nitrogen....I chuckle when that topic comes up on boards or in polite conversation. Unless your tire place is doing it for free because they have the ability I can't imagine any reason to go out of your way to do it.
MAY03LT
Delmarva
I put the beads in 2 customers super big tires and both of them were satisfied with the ride quality. They still felt like super big tires to me.
As for nitrogen, a few weeks ago our Napa rep was trying to pitch a nitrogen filling station. I think that was the first time I said "snake oil" in real life.
NJTB
612
Flemington, NJ
There are a few manufacturers of the beads. One is Dyna-beads. I used them in my motorcycle and swear by them, but never in a car tire.
Another type of balancer/sealer is Ride-On. It comes in a pressurized can and is used like a tire inflator. Difference is, it won't harden (according to their website), and balances the wheel while driving. It will also seal punctures.
northcreek
3,327
WNY
Any mention of what the beads might do to TPS? the sensors can be damaged easily as it is....just sayin',Mike.:undecided:
rodehawg
13
Halleluia and amen.
Wooluf1952
2,663
Milwaukee, Wisconsin
The only positive thing I've heard about nitrogen for street run tires, was on Motorweek.
If the air used is too damp, the moisture can damage the TMP sensors. If the air is run thru a dryer, even that problem could be eliminated. :twocents:
Feb 24, 2012
133
I saw that episode too. Moisture is the ONLY justified reason, and IMO not enough of a reason to justify the hassle. As was said earlier, if the tire place can do it for free because that's what they do, great. Otherwise it's not at all ever worth the effort on a street tire. Tire shops that don't take care of their compressors may have moisture problems in the air lines...
As for the beads, I haven't used them myself, but I know that truck shops and RV shops use them, and it does work. If the question is about ceramic vs some other type of bead, I have no idea. I would only use beads on very big tires that have trouble balancing, and it does take some guidance to know how much to put in.
northcreek
3,327
WNY
My son recently put new shoes on his Silverado and told me that they put balance bags in the tires eliminating the fugly weights and said that he was happy with the results. So today I took my wife's Malibu LTZ to Wally world to have my new Tire Rack Michelins installed and when I get home I noticed that there were no stick-on weights,the car drove great and now I'm thinking that they did the bag or ceramic bead thing,I'm going to check with them in the AM but, maybe someone here might know if Walmart made the switch too:undecided:...Mike.
DenaliHD66
Not all of my new tires needed any weights applied to them. Usually only the rears get weights on them.
4,656
If I remember correctly when I drove a commercial truck for a few years, the balance would settle once at speed and when you stop, they need to rebalance themselves.
I think if that was the case with passenger tires that would drive me crazy, but haven't used them in car tires.
Road force balance is the way to go IMO.
Stick on weights inside of face of wheel.
northcreek
3,327
WNY
I took a flashlight and looked again and...oops,I missed a few of the stick-ons on each wheel.I have to say that there is nowhere near the weights on these pricey Michelins that were required on the OE Goodyears....Mike.
DenaliHD66
Aye I got Michelin LTX MS2's and they are much smoother than my Bridgestones they replaced.
jonbo2002
213
There are these
Centramatic
work great on the Wife's Wrangler with 33's but they only work up to a certain weight so wheel weights may still be needed to make up the difference.
The centramatic rings?
jonbo2002
213
yes, sorry I should have said that. I read an artical on the testing of these, and forgive me if my numbers are wrong but I am not a wheel balancing expert, I belive they said these are good up to 4oz's out of balance. So when i got my wifes new spare mounted they told me it was still 2oz's off after they balanced it but they didn't want to put more weight on it. which was fine because the centramatic rings will make up for the rest. these are great when your running large tires which can sometimes need alot of wieght to ballance them. so someone like you who runs 33's or bigger these would be great, but like me who still has stock tires I think they would be a waste of money.
I would be getting them to spin the tire on the rim or have someplace else do it because that is BS on a 33.
...but
Good info. I am really wondering how balancing will work when I get tires for the beadlocks. The rings might really help then.
jonbo2002
213
yes I agree but it was only the spare, it was a used tire I got from work with real good tread left for free. but if it was one of her normal driving wheels they would be working on it till they got it right lol
memoremix
